17-08-2017 #81
Managed to find a quick hour to do a bit on the machine with not the best results :-(.
Anyway I have wired up the limit switches and installed a second cable track on the opposite side to the motor cables to try and keep them separate. I have also drilled and tapped some holes to help clip the cables nice and neat
The Following User Says Thank You to ravihotwok For This Useful Post:
17-08-2017 #82
I labelled each of the limit switch cables only to find I did the wrong lol, only need one cable per axis (2 switches)
Plugged it all in but its still not working correctly, motors seem to stop intermittently and something up with the y limit plug socket in the box.
I have not done anything to the settings apart from set the units per step which seem to be working now (when the motors don't stop)
I have sent an email to planet cnc and will do some more investigating tonight. Very frustrating as its starting to look really neat, just got to make sure the hardware has been assembled correctly
All a learning curve , be it a VERY frustrating one lol
Right chaps, had a bit more time to play with the machine and iron out some faults, it appears my motors seem to stop working off their own accord, if you jog it one way then it move fine until it meets a slight bit of resistance, then it just stop's, but makes a horrible noise and tries to move each way slightly. My motors are anchuan 57hd0401-15sb. Im hoping that this is due to the severe lack of torque? My theory was to buy a new set of motors anyway with my installing the larger spindle, so I may purchase just one new motor to clarify that the low torque is the problem. Anyone had any experince with this type of problem?
23-08-2017 #84
23-08-2017 #85
You would have thought even craptastically weak motors could move an unloaded x axis back and forth.
Seems likely to me that you may have some binding going on. Does it happen on all axis?
23-08-2017 #86
Morning Zee,
yes it does mate. I took the motor off the axes and it spins freely, but if you apply your finger to the output shaft it causes it to go mental
23-08-2017 #87
I spotted on another site about the motors something about these being 110v?
will try and find out
23-08-2017 #88
That's a bit disappointingly poor! even a little cheap nema 17 on my 3d printer driven from an onboard driver won't do that.
you may need to look at upgrading drivers as well/instead of motors... seems like they aren't giving the motor much juice if they stall that easily.
do you know what drivers you have in there at the mo?
23-08-2017 #89
23-08-2017 #90
this is what I have mate
https://planet-cnc.com/product/mk34-...e-accessories/
3020T Capabilities
By TT901 in forum Chinese MachinesReplies: 6Last Post: 03-03-2017, 04:20 PM -
Chineese 6040 problems
By Kendrick57 in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 18-10-2015, 10:52 PM -
Ballscrew for 3020T Y Axis
By richie00boy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 02-08-2013, 02:47 PM -
A viable mini-ish-mill build, or a hiding to nothing..?
By Wal in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 02-07-2013, 07:33 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
