Page 9 of 18 FirstFirst ... 7891011 ... LastLast
  1. Managed to find a quick hour to do a bit on the machine with not the best results :-(.
    Anyway I have wired up the limit switches and installed a second cable track on the opposite side to the motor cables to try and keep them separate. I have also drilled and tapped some holes to help clip the cables nice and neat
ID:	22589Click image for larger version.
ID:	22590Click image for larger version.
ID:	22591Click image for larger version.
ID:	22592Click image for larger version.
ID:	22593Click image for larger version.
ID:	22594Click image for larger version.
ID:	22595Click image for larger version.
ID:	22596Click image for larger version.
ID:	22597Click image for larger version.
ID:	22598Click image for larger version.
ID:	22599Click image for larger version.
    Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
  2. The Following User Says Thank You to ravihotwok For This Useful Post:
  3. I labelled each of the limit switch cables only to find I did the wrong lol, only need one cable per axis (2 switches)
    Plugged it all in but its still not working correctly, motors seem to stop intermittently and something up with the y limit plug socket in the box.
    I have not done anything to the settings apart from set the units per step which seem to be working now (when the motors don't stop)
    I have sent an email to planet cnc and will do some more investigating tonight. Very frustrating as its starting to look really neat, just got to make sure the hardware has been assembled correctly
    All a learning curve , be it a VERY frustrating one lol
    My build blog:
    Chinese 3020t Build
  4. Right chaps, had a bit more time to play with the machine and iron out some faults, it appears my motors seem to stop working off their own accord, if you jog it one way then it move fine until it meets a slight bit of resistance, then it just stop's, but makes a horrible noise and tries to move each way slightly. My motors are anchuan 57hd0401-15sb. Im hoping that this is due to the severe lack of torque? My theory was to buy a new set of motors anyway with my installing the larger spindle, so I may purchase just one new motor to clarify that the low torque is the problem. Anyone had any experince with this type of problem?
    My build blog:
    Chinese 3020t Build
  5. Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
  6. #85
    You would have thought even craptastically weak motors could move an unloaded x axis back and forth.
    Seems likely to me that you may have some binding going on. Does it happen on all axis?
  7. Morning Zee,
    yes it does mate. I took the motor off the axes and it spins freely, but if you apply your finger to the output shaft it causes it to go mental
    My build blog:
    Chinese 3020t Build
  8. I spotted on another site about the motors something about these being 110v?
    will try and find out
    My build blog:
    Chinese 3020t Build
  9. #88
    That's a bit disappointingly poor! even a little cheap nema 17 on my 3d printer driven from an onboard driver won't do that.
    you may need to look at upgrading drivers as well/instead of motors... seems like they aren't giving the motor much juice if they stall that easily.
    do you know what drivers you have in there at the mo?
  10. #89
    Quote Originally Posted by ravihotwok View Post
    the motors won't be 110v, if anything they'll be talking about the psu input. most switching psu i've seen these days are 110/220v but some do require you to move a jumper.
    one assumes if yours was set to 110v it would have gone pop already on 220v.
  11. Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
  1. 3020T Capabilities
    By TT901 in forum Chinese Machines
    Last Post: 03-03-2017, 04:20 PM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Ballscrew for 3020T Y Axis
    By richie00boy in forum Lead Screws, Nuts & Supports
    Last Post: 02-08-2013, 02:47 PM
  4. A viable mini-ish-mill build, or a hiding to nothing..?
    By Wal in forum Milling Machines, Builds & Conversions
    Last Post: 02-07-2013, 07:33 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
