Page 12 of 18 FirstFirst ... 21011121314 ... LastLast
  1. #111
    The other thing to watch out for when soldering boards like this is the tiny whisker of solder that bridges two connections. Can be difficult to see. Can't tell from the photo, but a scratch between adjacent soldereed pads with a small sharp implement may detect something, if there is anything there.
  2. The Following User Says Thank You to Neale For This Useful Post:
  3. right then massive update, followed your advice and the motorrs are running sweet. Back to the y axis limit switch I have also followed your advice and found there is a problem with the board, the pins are connected fine, but there is a break in the signal somewhere. Not sure where though. Think im going to gave to remove all the solders and remove it from the metal plate to have a nose ffs
    Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
  4. many thanks neale, after all the grief I got about my soldering skills (or lack of) that was my first port of call but they all look fine. I think I have found the problem. I have tested all the pins against each other and found an inconsistency with limit plug no2. All the other tests on the other plugs behave the same but when I do the same test on the no 2 plug nothing happens. There doesnt seem to be a visible circuitry on the pcb so i am guessing this is enclosed within the pcb somehow? uploading a vid now
    My build blog:
    Chinese 3020t Build
  5. here you go chaps, excuse the crappy diagram but just wanted to show the test
    https://youtu.be/ZIXuiPqgiY0
    My build blog:
    Chinese 3020t Build
  6. The Following User Says Thank You to ravihotwok For This Useful Post:
  7. will be sending this info back to planet and hopefully get a new one sent out. This will give me a chance to finalise my wiring and get the earthing sorted. Just really motivated now thanks to you guys, getting the motors to work properly has really cheered me up.
    My build blog:
    Chinese 3020t Build
  8. The Following User Says Thank You to ravihotwok For This Useful Post:
  9. #116
    possible when you were removing the solder you pulled up or otherwise damaged the copper trace around the hole... If so you should be able to see the trace in question, just scratch off the surface next to your solder blob and run solder to the trace. Alternatively you could run a small jumper wire or use a pcb repair pen.
  10. Well bit of an update. I sent rhe pcd back to planet nd they emailed me back the day they received it saying there was a faulty bit of soldering on rhe board which they have rectified and tested. It is now back with me and I have re fitted it. This all took 3 days fir play to them foe sorting it quickly. Anyway I have been stripping the old control box to now house the stuff for the spindle motor
  11. Here is the old box, I stripped it and sprayed it the same as the new control box as I want to mount the 2 together.
    Now I mounted the power supply thing and bolted it now, I spaced it about 5mm up off the deck to help air flow, not sure if it is needed but though as there are vents on the underside it would make sense.
    My build blog:
    Chinese 3020t Build
  12. Now I have to find a place to fit the small pcb which has the speed control dial plugged into it
ID:	22769Click image for larger version.
ID:	22770Click image for larger version.
ID:	22771Click image for larger version.
    Is it ok to mount this box directly ontop of my new box so it is nice and neat? I think the power will go from one box to another so it would be much neater if the cables were kept internal hence linking the boxes?
    My build blog:
    Chinese 3020t Build
  13. Well another update,
    I have rewired the limit switches correctly as I did it wrong the first time, I have also added ground wires to the shielding on the motor wires to connect to the star on the box I made. With the new diy motor power box I have made that is not fitted to the top of the planet box and I have begun wiring it into the planet cnc controller, just waiting on some confirmation off Planet CNC that I have wired it in correctly. I have soldered and heatshrunk the wires. Also installed a e-stopClick image for larger version.
ID:	22934Click image for larger version.
ID:	22935Click image for larger version.
ID:	22936Click image for larger version.
ID:	22937Click image for larger version.
ID:	22938Click image for larger version.
ID:	22939Click image for larger version.
Name:	black wire capped off.jpg
ID:	22940Click image for larger version.
ID:	22941Click image for larger version.
Name:	gnd - 1.jpg
ID:	22942Click image for larger version.
Name:	gnd - 2.jpg
ID:	22943Click image for larger version.
ID:	22944Click image for larger version.
Name:	pin6 - 1.jpg
ID:	22945Click image for larger version.
Name:	pin6 - 2.jpg
ID:	22946Click image for larger version.
Name:	pin6 - 3.jpg
ID:	22947Click image for larger version.
ID:	22948Click image for larger version.
Name:	spindle power cable.jpg
ID:	22949 button but need to work out how the hell that gets wired in lol. One job at a time
ID:	22927   Click image for larger version.
ID:	22926   Click image for larger version.
ID:	22928   Click image for larger version.
ID:	22929   Click image for larger version.
Name:	gnd - 1.jpg
ID:	22930   Click image for larger version.
ID:	22931   Click image for larger version.
Name:	pin6 - 2.jpg
ID:	22932   Click image for larger version.
    My build blog:
    Chinese 3020t Build
  14. The Following User Says Thank You to ravihotwok For This Useful Post:
  1. 3020T Capabilities
    By TT901 in forum Chinese Machines
    Last Post: 03-03-2017, 04:20 PM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Ballscrew for 3020T Y Axis
    By richie00boy in forum Lead Screws, Nuts & Supports
    Last Post: 02-08-2013, 02:47 PM
  4. A viable mini-ish-mill build, or a hiding to nothing..?
    By Wal in forum Milling Machines, Builds & Conversions
    Last Post: 02-07-2013, 07:33 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
