05-07-2017 #17
Are you applying the solder to the iron and then putting it on the part if so that is wrong. You need to put the iron on the part and then apply the solder to the part and you should see it flow. Some people when learning just dab the iron but the part needs about 1-2 secs of heat depending how big the iron is.
3020T Capabilities
By TT901 in forum Chinese MachinesReplies: 6Last Post: 03-03-2017, 04:20 PM -
Chineese 6040 problems
By Kendrick57 in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 18-10-2015, 10:52 PM -
Ballscrew for 3020T Y Axis
By richie00boy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 02-08-2013, 02:47 PM -
A viable mini-ish-mill build, or a hiding to nothing..?
By Wal in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 02-07-2013, 07:33 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
