26-07-2017 #23
It's not a recommendation, but this works for me:
From the top, spindle power (screened CY) runs in the same cable guide as the Z limit proximity switch (unscreened 3-core) and Z stepper power (screened CY). Next level down they are joined by Y motor power and Y limit/home switches. These run together in about 2m of cable guide before splitting to go to various places (junction boxes, sockets on control box). Where screened cable is used, screens eventually go to star point in control box but screens are only connected at one end. Each cable guide also contains an earth wire which connects to the metalwork at each end of the cable guide to make sure that there is a reliable earth connection right from the spindle to the control box so I never rely on electrical connections via the linear bearings. As much as anything, this is to make sure that the touchplate connection is reliable.
I have had a couple of problems with the proximity switches but these are switch issues which I have been able to fix (and possibly due to using some of the cheapest switches available on eBay) and I have had absolutely no noise issues whatsoever from day one. Maybe it's luck although apart from ignoring advice to run power and switch cables separately, I have generally followed good wiring practice. I do also use 24V for the proximity switches (which my motion controller is happy to accept) and that also helps noise issues.
3020T Capabilities
By TT901 in forum Chinese MachinesReplies: 6Last Post: 03-03-2017, 04:20 PM -
Chineese 6040 problems
By Kendrick57 in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 18-10-2015, 10:52 PM -
Ballscrew for 3020T Y Axis
By richie00boy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 02-08-2013, 02:47 PM -
A viable mini-ish-mill build, or a hiding to nothing..?
By Wal in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 02-07-2013, 07:33 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
