Quote Originally Posted by ravihotwok View Post
Well I managed to have a good session on the control box tonight and my first ever stab at soldering, its a lot harder than it looks.
First job was to solder the pins to the board for the motor connections and other plugs which in not sure of lol
ID:	22075Click image for larger version.
Sorry, but all the soldering joints you made looks like really bad work. I would redo this. Get a solder sucker like this...
...remove every large clump, make sure your soldering iron is not too large but is designed for the purpose and that the solder wire is thin enough, quickly melting and floating well on the surface. The surface must be clean and the tip of the soldering iron must be kept clean using the wet sponge. I clean it after each and every soldering point.
Here are a few do:s and don't:s:
You need to practice on something which is not going to be used, not something which you need later on for reliable operations. Get a magnifier and check/fix every point. You will get a lot of headache later on if you box this and start using. Even if it works now, it may fail at any time.
