    So far the only advice he's had is to get a solder sucker and start again
    Well, that's not very fair, is it? Did you not read post #53 and #56? That's all there is to it. Like you say, soldering is not rocket science, but needs some practice. He was given a google link but I did not pick any specific video, I think he should do that selection on his own.
    My iron is a 24v 50W Weller from 1978. It still works well. Of course, it does not have the fancy temperature regulator and display, but I never really felt any need for that.
    I have used up several tips and also have different type, depending on the purpose, I change when necessary. I would not use a high voltage type of iron, which the 12W you have been given is, on any electronics, but I know many people use tools which are not suitable. Anyway, while it may have a nostalgic value for you, I personally would only keep it as a memory.
    Regarding flux, I stand by what I have said. It is waste of money. On electronics one should not use any other type of soldering wire than the one with flux in the core of the wire. As a matter of fact, too much flux can also cause problems, so it is not true that using flux can not hurt. Flux fluid is used only in industrial soldering, where the PCB is travelling through a flux foam first and then through the melted soldering wave.
    Manual soldering of electronics don't need any flux foam or liquid.
    My experience is that if there are balls then it is enough to heat them well up, until completely melted and either suck it up or in many case it will float out because there is normally enough flux around the points. If if does not float out and look like figure A in the picture I provided then there is nothing else to do than suck it out and apply new solder.
    Takes a 15 minutes to half an hour practising and that's it. Really very simple.
  1. 3020T Capabilities
    By TT901 in forum Chinese Machines
    Last Post: 03-03-2017, 04:20 PM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Ballscrew for 3020T Y Axis
    By richie00boy in forum Lead Screws, Nuts & Supports
    Last Post: 02-08-2013, 02:47 PM
  4. A viable mini-ish-mill build, or a hiding to nothing..?
    By Wal in forum Milling Machines, Builds & Conversions
    Last Post: 02-07-2013, 07:33 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
