    looks like these are the drivers https://planet-cnc.com/product/motordriver-2-5a-32/
    says current selectable.... i would say there is a good chance the current is set too low.
  2. hmm, sounds interesting mate. Is this a variable that is changed via the software or manually on the control board?
    Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
    i would guess a jumper or pot on the board.
  4. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  5. #4
    looking at the pics, you have a little dip switch to choose the micro stepping setting, so chances are the red jumper is your amperage setting.
    edit - infact I think i can make out "Imax" next to the jumper in one pic, so thats almost certainly the puppy. Check what it is set to.
  6. I will go and have a look at my pics now matey
    My build blog:
    Chinese 3020t Build
  7. #6
    Looks like your motors are 2.0A from a quick google (you may want to verify that yourself) so thats the setting you'd want on the drivers
  8. right I understand exactly what you mean, the 4 little boards are the drivers, and there is a jumper on the 2 pins the other side to the 2 pins labelled imax
    My build blog:
    Chinese 3020t Build
  9. I have looked at the pics of my install and the jumper is on the same 2 pins as in the advert on the site ie opposite to imax. Should I put the jumper onto the imax pins?
    My build blog:
    Chinese 3020t Build
  10. #9
    yeah those are your drivers, what you referred to in an earlier post as your new driver board is actually your motion control board.
    Again, only working from educated guesses given the blurry pics on their website an no instructions, but you have two variables you can set on those drivers. micro stepping and amps. the micro stepping looks like it is set by the small dip switch, which leaves the red jumper for amps. one assumes the different jumper positions correspond to 0.5, 1.0, 1.5, 2.0 and 2.5 amps... if that is a correct assumption then you'd want the second from last pins if your motors are indeed 2.0A
  11. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  1. 3020T Capabilities
    By TT901 in forum Chinese Machines
    Last Post: 03-03-2017, 04:20 PM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Ballscrew for 3020T Y Axis
    By richie00boy in forum Lead Screws, Nuts & Supports
    Last Post: 02-08-2013, 02:47 PM
  4. A viable mini-ish-mill build, or a hiding to nothing..?
    By Wal in forum Milling Machines, Builds & Conversions
    Last Post: 02-07-2013, 07:33 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
