23-08-2017 #22
You have explained a hell of a lot this morning mate, in very easy terms. I really appreciate that mate, hopefully this will solve the problem but even if it doesnt I have just gained a lot of useful knowledge in regards to my box. In other news I have been in constant contact with planet regarding my issues, I have now begun to learn how to add shortcuts into the planet software, the jogging buttons on the front of the box itself now work which is a nice little touch, managed to get one limit switch working on the z axis but the others are wired wrong. Bit worried about the y axis though as when I plugged the z axis into it nothing at all happens, there is a i/o tab on the software which shows when a input is activated, put the z limit switch cable into the x axis and it registers a input but with the y axis nothing at all happens. Need to check my soldering but im pretty sure that is ok now.
3020T Capabilities
By TT901 in forum Chinese MachinesReplies: 6Last Post: 03-03-2017, 04:20 PM -
Chineese 6040 problems
By Kendrick57 in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 18-10-2015, 10:52 PM -
Ballscrew for 3020T Y Axis
By richie00boy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 02-08-2013, 02:47 PM -
A viable mini-ish-mill build, or a hiding to nothing..?
By Wal in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 02-07-2013, 07:33 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
