09-10-2017 #11
Hi Ravi,
You need to connect that Power Supply you have to 230v AC - Mains Voltage.
Looking at the PSU you have the far right three terminals: Earth, Live, Neutral.
Get a common Kettle Plug (For a PC or a PC Monitor etc), cut end off and use it to power the PSU.
USUALLY - in a typical plug it is as follows:
Blue - Neutral
Brown - Live
Green / Yellow - Earth
If you want to be neat about it then you can get one of these: Click Me
That will you mean you can just plug it in and have it modular.
Once you have the PSU live, you just need to (I assume - I do not know what you have been supplied to control the spindle), power the PCB using 48v DC from the PSU using any of the remaining terminals. You have 3 sets of -V & +V on the left hand side of the PSU.
AlexLast edited by AlexDoran; 09-10-2017 at 03:09 PM.
The Following User Says Thank You to AlexDoran For This Useful Post:
3020T Capabilities
By TT901 in forum Chinese MachinesReplies: 6Last Post: 03-03-2017, 04:20 PM -
Chineese 6040 problems
By Kendrick57 in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 18-10-2015, 10:52 PM -
Ballscrew for 3020T Y Axis
By richie00boy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 02-08-2013, 02:47 PM -
A viable mini-ish-mill build, or a hiding to nothing..?
By Wal in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 02-07-2013, 07:33 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
