Page 15 of 18 FirstFirst ... 51314151617 ... LastLast
  1. #141
    Quote Originally Posted by ravihotwok View Post
    They say motor - &+ so I think I wired these up wrong, think these are supposed to go to the actual spindle?
    Yes those are supposed to go the spindle, no biggy just swap them to the correct terminals on the PCB.
    Do you know what the draw is of the spindle? I would advise against running that new PSU for the spindle through that On / Off switch, i would just power the Spindle PSU direct from the IEC / Kettle Plug, if you want to be able to turn it on & off away from using the wall plug, then get one of those additional IEC / Kettle Plug mounts from ebay like i linked.
    You need to wire that PCB to the Spindle PSU, just take 'Power -' on the PCB to a 'V-' terminal on the PSU and the same for 'Power +' to 'V+'.
    That should be all you need to do in terms of power.
    Alex
  2. Hello Alex mate,
    here is some info for the spindle:
    Brushless Spindle DC Motor:
    Working Voltage: 48V DC
    Rotation Speed: 12000r/min max
    Power: 400W
    Torque: 230mN.m
    Insulation Resistance: >2Megohm
    Dielectric Strength: 400V
    Diameter: 52mm
    Axis Collet Length: 48mm
    Diameter of Axis Collect Holder: 16mm
    ER11 Collect: 3.175mm
    Power supply (enough power for motor):
    Input: AC220V ±10%, 50Hz
    Output: DC48V, 10A
    Power: 480W
    Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
  3. Click image for larger version.
    Am i on the right track at last?
    My build blog:
    Chinese 3020t Build
  4. #144
    Yeah based on the info you gave there i probably would not wire that PSU through those small wires & switch.
    Yeah your drawing looks good that is how it should be wired.
    Alex
  5. Thanks very much mate, I bet everyone is banging there heads against their screens with my lack of knowledge lol
    My build blog:
    Chinese 3020t Build
  6. #146
    Not at all mate, the thing is with electronics, is if you just guess and turn it all on you quickly realise that all you have to show for your work is a bit of smoke and a new shopping list of parts haha
    Alex
  7. The Following User Says Thank You to AlexDoran For This Useful Post:
  8. I totally agree, once i have done this wiring do you think im better leaving the spindle unplugged at the motor just while I make sure the software is communicating etc?
    My build blog:
    Chinese 3020t Build
  9. right its been a long while since i last updated this, I sent the control box back to planet CNC as it was faulty, I received it back pretty quickly a good while ago but have yet to plug it all in.......until tonight. Well the results were a bit disappointing,and now the motors will only move one way. I have sent another email to planet but even though im about £600 down on this control box I think I may need to buy another one which is wider used. Can anyone offer any advice as to if I should persevere with this box of just cut my losses and move on?
    There are LED's on the front of the cnc control box but I cannot find anywhere what they mean as one of them is flashing and another is flashing red which obviously means something :-(
    My build blog:
    Chinese 3020t Build
  10. #149
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    Too early to call. But I'm a big fan of fixing, rather than replacing random bits.
    You say "the motors will only move one way" - you're referring to the axis stepper motors? (the last part of this thread was discussing the spindle motor, but from the tense of your comment here I think you're talking axis?.
    On the assumption you're talking axis...
    What's changed?, just the control box? (which eliminates, to some degree) software set-up in Mach3 (assuming this is what you're using). Assuming that it's just the control box then it's unusual to lose all three axis at once. That to me sounds more like a configuration issue than failure (though lets not rule that out!)
    How are you testing each axis?, front-panel switches, or from G-Code loaded into Mach3? Have you tried both? If the front-panel - are you saying that, eg, "Left moves left, Right moves left"?, or "Left moves left, Right doesn't move"? - it helps to understand better the nature of the problem.
    If following a failure-more: You're now playing a diagnostic game. At least with losing one direction off one or more axis you can do some sensible diagnostics pretty easily (the step/dir interface typical of these boards means that the direction line is somewhat low frequency and easily measurable/set-able). I'd be looking to scope the dir signal with the axis being driven alternate directions. If no scope, then DVM, if no DVM then LED & resistor, and so on. You'd be wanting to start at the control board, then move to the stepper drivers. Even a visual inspection might help, though I guess you've done this. The control box looks to be wired with IDC connectors - you might have to knock a diagnostic lead up that breaks-out the DIR line (or allows you to drive it 0/1 without shorting the control box).
    For me - not enough info at this time, I appreciate you're probably frustrated - and that's the worst frame of mind to diagnose problems with - at least for me. Try breaking the problem down to succinct points and either understand each of them, or post them here to be critiqued.
    From the manual:
    2.2.11 Mk3/4 LED indicators
    The user is provided with helpful feedback and live ‘status’ information via on-board LED indicators. There are four indicators.
    POWER: Lights when the controller is powered.
    DATA: Indicates controller functions.
    LINK: Indicates controller communication.
    STATUS: Blinks to indicate controller function is ‘good’.
    Which are flashing?, it sounds like at least one should be.
  11. well im afraid this is a bit of a humble response. The machine appears to be working fine lol. Im not sure why as im still learning the software but the axis on the screen where coloured red. The ones which were coloured red were the onces which would move correctly. I had a play with the limits (nto exactly sure what im doing) and they went back to normal and not red, this allowed normal travel while jogging.
    I have also managed to set the limit switches up so now ever axis will stop just before its normal end of travel.
    This is a massive milestone for me!!! Faith has been restored in the machine and control box.
    Now all I need to do is learn how to set it up correctly which is way above my head. Been looking online and even the most basic of tutorials seem a bit advanced. Lots of special terminology to take in.
    I think the first thing I need to get my head around is homing, which im still a bit in the dark with lol
    Main thing is the machine is jogging correctly and when I type for example x10 the spindle moves exactly 10mm, ive tested all axis in all directions and confirmed all is good. Sounds daft but im soooo chuffed to even be able to do that
    My build blog:
    Chinese 3020t Build
  1. 3020T Capabilities
    By TT901 in forum Chinese Machines
    Last Post: 03-03-2017, 04:20 PM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Ballscrew for 3020T Y Axis
    By richie00boy in forum Lead Screws, Nuts & Supports
    Last Post: 02-08-2013, 02:47 PM
  4. A viable mini-ish-mill build, or a hiding to nothing..?
    By Wal in forum Milling Machines, Builds & Conversions
    Last Post: 02-07-2013, 07:33 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
