  1. Right chaps,
    had a bit more time playing with the machine, ive got the motion speed set pretty low, feed rate set at 200. But it seems to be struggling with right angles and sharp points, it seems to add a small radius in these areas even though on the preview on the software there are clear points.
    Any ideas?
ID:	24400Click image for larger version.
ID:	24401Click image for larger version.
    Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
    Google Mach3 Constant Velocity
  3. The Following User Says Thank You to Doddy For This Useful Post:
  4. Just had a quick read, ive now changed the motor speeds in my planet software from 500 to 200
    seems to have sorted it i think, bloody slow now though lol
    My build blog:
    Chinese 3020t Build
  5. #4
    Quote Originally Posted by ravihotwok View Post
    Sorry, missed that you was using Planet CNC software. Check this out http://forum.planet-cnc.com/viewtopic.php?f=5&t=1271 (no promises!)
  6. managed to speed up the motors to 500, but changed the blend value to 0. Machining fine now, but a bit stop start on curves
    My build blog:
    Chinese 3020t Build
  7. not much of an update but ive begun sourcing parts for the new extraction system and also the new enclosure. Ive tidied up my tool bench and moved it from the back wall against my booth which has free'd up some more space. Also got a big screen dedicated to the cnc stuff
    I have made some small holes for the machine wires to drop neatly through the base of the enclosure so it is nice and neat, will be going to screwfix later to pick up some odds and sods for the extraction system. Im happy with the setup so far :-)
    My build blog:
    Chinese 3020t Build
  8. Click image for larger version.
ID:	24659Click image for larger version.
ID:	24660Click image for larger version.
ID:	24661Click image for larger version.
ID:	24662Click image for larger version.
    My build blog:
    Chinese 3020t Build
  9. small update with the new setup, extraction system is all done, just sorting the power supply to the rear fans, I bought a transformer but its ac - ac instead of dc so need to get another one then that will be able to power the fans via a variable speed controller. small progress but starting to look the part
    My build blog:
    Chinese 3020t Build
  1. 3020T Capabilities
    By TT901 in forum Chinese Machines
    Last Post: 03-03-2017, 04:20 PM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Ballscrew for 3020T Y Axis
    By richie00boy in forum Lead Screws, Nuts & Supports
    Last Post: 02-08-2013, 02:47 PM
  4. A viable mini-ish-mill build, or a hiding to nothing..?
    By Wal in forum Milling Machines, Builds & Conversions
    Last Post: 02-07-2013, 07:33 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
