  1. Now I had to wire in the cables for the limit switches, this was a little bit fiddly, I used a few small pieces of heat shrink to help keep the cables together.
ID:	22082Click image for larger version.
ID:	22083Click image for larger version.
    Now to attached the ribbons for each axis.
    Thats all I managed last night, all that needs doing now is wiring the octocoupler in (which I have no idea what that is)
    Really happy with it so far, hopefully have it fired up in the next few days fingers crossed
    Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
    Its hard to see and I am not picking holes but the soldering on the board does not look good. Its looks like it is balled up that is an indication of a newbie not leaving the iron on long enough for the sold to flow (common mistake) I would re flow some of the joints.
  3. pick away clive mate
    this is what I need so I welcome any advice mate. Before I made that sort of ball on the top I filled the hole underneath with solder, then tried to get that dome shape just for neatness, but I did fill the prong on the switch. Not to sure if I soften the solder I can do much else
    My build blog:
    Chinese 3020t Build
    Quote Originally Posted by ravihotwok View Post
    Are you applying the solder to the iron and then putting it on the part if so that is wrong. You need to put the iron on the part and then apply the solder to the part and you should see it flow. Some people when learning just dab the iron but the part needs about 1-2 secs of heat depending how big the iron is.
  5. No mate, I watched a few tutorials on youtube, I held the tip of the iron against the prong on the switch for a short while then placed the wire against the prong, as soon as it melted I let it fill the hole till about 3mm, then I removed the wire and slowly lifted the iron away to leave that dome shape. I was also careful to keep the end of the iron clean with a special sponge I bought from maplin. I never realised just how fiddly soldering is! and time consuming,
    My build blog:
    Chinese 3020t Build
    But when did you apply the solder?
  7. time wise? think it was about5 - 8 sec? not too sure if im honest clive mate, but when it was melting plenty seeped in
    My build blog:
    Chinese 3020t Build
  1. 3020T Capabilities
    By TT901 in forum Chinese Machines
    Last Post: 03-03-2017, 04:20 PM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Ballscrew for 3020T Y Axis
    By richie00boy in forum Lead Screws, Nuts & Supports
    Last Post: 02-08-2013, 02:47 PM
  4. A viable mini-ish-mill build, or a hiding to nothing..?
    By Wal in forum Milling Machines, Builds & Conversions
    Last Post: 02-07-2013, 07:33 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
