Its hard to see and I am not picking holes but the soldering on the board does not look good. Its looks like it is balled up that is an indication of a newbie not leaving the iron on long enough for the sold to flow (common mistake) I would re flow some of the joints.
05-07-2017 #2
pick away clive mate
this is what I need so I welcome any advice mate. Before I made that sort of ball on the top I filled the hole underneath with solder, then tried to get that dome shape just for neatness, but I did fill the prong on the switch. Not to sure if I soften the solder I can do much else
05-07-2017 #3
Are you applying the solder to the iron and then putting it on the part if so that is wrong. You need to put the iron on the part and then apply the solder to the part and you should see it flow. Some people when learning just dab the iron but the part needs about 1-2 secs of heat depending how big the iron is.
05-07-2017 #4
No mate, I watched a few tutorials on youtube, I held the tip of the iron against the prong on the switch for a short while then placed the wire against the prong, as soon as it melted I let it fill the hole till about 3mm, then I removed the wire and slowly lifted the iron away to leave that dome shape. I was also careful to keep the end of the iron clean with a special sponge I bought from maplin. I never realised just how fiddly soldering is! and time consuming,
05-07-2017 #5
05-07-2017 #6
time wise? think it was about5 - 8 sec? not too sure if im honest clive mate, but when it was melting plenty seeped in
05-07-2017 #7
Are you using lead free solder?
3020T Capabilities
By TT901 in forum Chinese MachinesReplies: 6Last Post: 03-03-2017, 04:20 PM -
Chineese 6040 problems
By Kendrick57 in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 18-10-2015, 10:52 PM -
Ballscrew for 3020T Y Axis
By richie00boy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 02-08-2013, 02:47 PM -
A viable mini-ish-mill build, or a hiding to nothing..?
By Wal in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 02-07-2013, 07:33 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
