  1. Cheers Andy mate
    Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
  2. right im at work doing a bit of skiving watching homeland and messing with this control box, I have re soldered the plug connections as advised, pelase have a look and give me your thoughts, don't think I can do much better if I'm honest
    before
ID:	22101Click image for larger version.
    And now after re soldering
ID:	22103Click image for larger version.
ID:	22104Click image for larger version.
ID:	22105Click image for larger version.
    My build blog:
    Chinese 3020t Build
    Ravi They are better but some are not good. It does take practise I think you said you have leaded solder.
    You will have to power it up and see. Remember always apply the solder to the joint (its ok to wet the iron first with solder) It should run and not ball up. What is the wattage of your iron?
  4. i have balled it up deliberately, once I had allowed plenty to go into the terminal i then gently moved the iron in a circular motion to ensure the solder didnt interfere with the next one. Iron is 30watt matey
    My build blog:
    Chinese 3020t Build
    Too much solder, you should be able to see the shape of the parts after they are soldered.
  6. Did a bit more on the machine this weekend, my new 600w spindle and pwr supply arrived as well
    I have allso installed the limit switches, 2 on each x and y axis and one on the z axis
ID:	22154Click image for larger version.
ID:	22155Click image for larger version.
ID:	22156Click image for larger version.
ID:	22157Click image for larger version.
    My build blog:
    Chinese 3020t Build
  7. The Following User Says Thank You to ravihotwok For This Useful Post:
  8. A common problem with this model of cnc machine is excess play on the z axis, this is caused by a small gap from the top of the screw and the bearing just where it meets the motor. It is only about 1.5mm but is enough to worry you. Using a 3d printed washer I have solved this problem and now there is zero play in the z axis, got the idea from a funny chap off youtube.
    Here is the excess play before
    https://www.youtube.com/watch?v=r9aK...ature=youtu.be
    Here is how I solved it:
    I started with printing some washers
    8mm id 11mm od 2mm thickness
ID:	22177Click image for larger version.
    Now to remove the motor, and then the 2 retaining screws on top of the bearing
ID:	22179Click image for larger version.
ID:	22180Click image for larger version.
    Now slide the printed washer onto the screw
    Now install the bearing again, you must make sure that the bearing is flush with the top of the housing it is seated in, I had to sand about half a mm off to achieve this, once happy tighten the 2 retaining screws and then install the motor.
    Here is the result
    https://www.youtube.com/watch?v=YBEN...ature=youtu.be
    No play at all and the axis still moves nice and freely. An easy fix to what really should of been sorted at factory.
    Hope this helps someone in the future :-)
    My build blog:
    Chinese 3020t Build
  1. 3020T Capabilities
    By TT901 in forum Chinese Machines
    Last Post: 03-03-2017, 04:20 PM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Ballscrew for 3020T Y Axis
    By richie00boy in forum Lead Screws, Nuts & Supports
    Last Post: 02-08-2013, 02:47 PM
  4. A viable mini-ish-mill build, or a hiding to nothing..?
    By Wal in forum Milling Machines, Builds & Conversions
    Last Post: 02-07-2013, 07:33 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
