Too much solder, you should be able to see the shape of the parts after they are soldered.
10-07-2017 #2
The Following User Says Thank You to ravihotwok For This Useful Post:
11-07-2017 #3
A common problem with this model of cnc machine is excess play on the z axis, this is caused by a small gap from the top of the screw and the bearing just where it meets the motor. It is only about 1.5mm but is enough to worry you. Using a 3d printed washer I have solved this problem and now there is zero play in the z axis, got the idea from a funny chap off youtube.
Here is the excess play before
https://www.youtube.com/watch?v=r9aK...ature=youtu.be
Here is how I solved it:
I started with printing some washers
8mm id 11mm od 2mm thickness
Now to remove the motor, and then the 2 retaining screws on top of the bearing
Now slide the printed washer onto the screw
Now install the bearing again, you must make sure that the bearing is flush with the top of the housing it is seated in, I had to sand about half a mm off to achieve this, once happy tighten the 2 retaining screws and then install the motor.
Here is the result
https://www.youtube.com/watch?v=YBEN...ature=youtu.be
No play at all and the axis still moves nice and freely. An easy fix to what really should of been sorted at factory.
Hope this helps someone in the future :-)
26-07-2017 #4
Been very busy with work so been restricted when I can play with the machine, I have been plodding along in the back ground though. I have no fully re wired the stepper motors to the controller, I have binned the cheap 5 core unscreened power cables for a thicker screened 5 core cable and freshly soldered them to the plugs. These were a complete nightmare to try and fish through the cable track but I got there in the end. Once wired up the motors were making a high pitch noise, also when trying to jog any of the axis they just seemed to move back and fourth which is a tell tale sign of the wrong core pairs being wired up. For anyone interested, my motors are 4 cable motors, which means it has 2 coils with 1 pair of cables per coil. I used the multimetre to find when 2 of the cables were connected a circuit was made, that way I could establish which cables were paired together. The I wired one pair to pins 1 and 2, and the other to 4 and 5 of the 5 pin plug and hey presto it worked well. I have made the length of the cables just shy of 3m for now as im making a full enclosure so thought it is much easier to cut the cables back than to add in AND RE-FISH THROUGH THE CABLE TRACK LOL
Anyway here is a few pics, limit switches are to be done tonight then I can start setting the controller up through the software which I really have no idea how to do but got plenty of literature from Planet CNC to guide me, would like to mention they have been very supportive throughout this build even though I have been bombarding them with daft question constantly.
26-07-2017 #5Did you ground the screens at one end?I have no fully re wired the stepper motors to the controller, I have binned the cheap 5 core unscreened power cables for a thicker screened 5 core cable and freshly soldered them to the plugs...Clive
26-07-2017 #6
Nope, Planet said there was no need to?
26-07-2017 #7
3020T Capabilities
By TT901 in forum Chinese MachinesReplies: 6Last Post: 03-03-2017, 04:20 PM -
Chineese 6040 problems
By Kendrick57 in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 18-10-2015, 10:52 PM -
Ballscrew for 3020T Y Axis
By richie00boy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 02-08-2013, 02:47 PM -
A viable mini-ish-mill build, or a hiding to nothing..?
By Wal in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 02-07-2013, 07:33 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
The vast majority on here would disagree I think.
