26-07-2017 #2
Advise welcome, instructions even better. Searching is great, but is something can be answered in a simple sentence then that saves a lot of time. Will do a search now and see what I can find.
That wiki link explains a lot. Except the best way to go about physically achieving it.
26-07-2017 #3
I now understand what a star point is. Can I splice into each of the motor cables just to expose the outer metal braid, then solder/heatshrink a cable to it which can then me linked to a star point in the box?
26-07-2017 #4
the screen is just metal that picks up the noise and passes this noise back to ground as current, so as long as you have a good connection to ground that is all you need. so use your initiative and solder a wire onto the screen and connect it to gnd.
how you do it is up to you and depends on how messy you can accept.Visit Us: www.automationshop.co.uk
The Following User Says Thank You to Gary For This Useful Post:
26-07-2017 #5
Great Gary, I understand that. Im pretty sure I can do that nice and neat and finish off with a bit of heatshrink to keep it all covered up.
26-07-2017 #6
The Following User Says Thank You to Lee Roberts For This Useful Post:
26-07-2017 #7
Awesome lee, instead of doing it like that I will do it a bit further back as ive got plugs on the end of my cable which connect into the planet control box. But I will put a earth point where the plugs go into the box, so there will only be a short length from the motor cable to the box for earth, should look reasonably neat. Thanks chaps for explaining in laymans terms, helped a lot. Will crack on later tonight and report back with some more pics
3020T Capabilities
By TT901 in forum Chinese MachinesReplies: 6Last Post: 03-03-2017, 04:20 PM -
Chineese 6040 problems
By Kendrick57 in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 18-10-2015, 10:52 PM -
Ballscrew for 3020T Y Axis
By richie00boy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 02-08-2013, 02:47 PM -
A viable mini-ish-mill build, or a hiding to nothing..?
By Wal in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 02-07-2013, 07:33 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
