27-07-2017 #11
I can't spend time marking every point, but like I said, get a good magnifying glass and have a look at each one of them. Unless they are not looking like the one marked A in that picture I posted above, you have to redo it. Most of the ones I have seen in your pictures (not only in the one I linked to) are bad. If you have a ball it means the solder wire did not melt and floated out, or there was dirt on the surface or the iron or you did not heat up the wire you solder AND the surface you solder it to and so on... Just google "how to solder" and you will find millions of answers regarding soldering with pictures and Youtube video, so I will not go into more details.
3020T Capabilities
By TT901 in forum Chinese MachinesReplies: 6Last Post: 03-03-2017, 04:20 PM -
Chineese 6040 problems
By Kendrick57 in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 18-10-2015, 10:52 PM -
Ballscrew for 3020T Y Axis
By richie00boy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 02-08-2013, 02:47 PM -
A viable mini-ish-mill build, or a hiding to nothing..?
By Wal in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 02-07-2013, 07:33 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
