27-07-2017 #2
Ravi,
Just a couple of notes:
1. There is to much solder on each one
2. Get yourself some soldering flux, liquid preferable
The flux and soldering go hand in hand, when the solder "flows" better (you'll see the diffrence) because of the flux, it just works and you'll see what I mean about there being to much on each joint.
Flux isn't cheap depending on what you get, however if you get liquid flux you simply apply a very small amount, so it last's a long time.
If you keep application to a minimum you wont need to do a lot of clean up, in fact look for no-clean flux, I like to use isopropanol alcohol to clean any soldering/pcb jobs I do.
Links below for what I use, just dip your tip in the Kalafonia tin before each pass.
ALCOHOL BASED SOLDERING LIQUID FLUX SMD/RMA REWORK, REFLOW, REBALL, NO CLEAN
COLOPHONY/KALAFONIA Limited offer 40g for the price 20g tin Solid soldering flux
IPA 100% | 1 LITRE | Lab/Pharma. Grade | Isopropyl Alcohol/Isopropanol (99%) 1L
Look forward to seeing the rework :)Last edited by Lee Roberts; 27-07-2017 at 05:08 PM. Reason: added links
sakes lads ive just bought some flux but its hard stuff, will up load a pic in a mo. Im going to spend sat afternoon redoing these solders, thanks for explaining it in detail, I thought it balled due to me putting enough into the area and the solder had no where else to go so created the ball. Now I know this isnt the case and can revisit it with the knowledge of what im trying to achieve.
On another note, I want to buy new steppers a mine appear to be proper crap. Any recommendations for 3 motors that will fit my machine? budget of £120 for all 3?
27-07-2017 #4
Ok, well the better value option to what I linked would be to buy some solid Rosin like this eBay - Rosin Resin and mix it with the Isopropyl I linked to above, brake the rosin up and add to the Iso untill your happy with the viscosity.
Here is a video on that:
Don't know what flux you've got but i'm sure you can change its viscosity, again the Isopropyl is what you want but nail varnish remover is made from Acetone and Isopropyl is what you get from the Hydrogenation of Acetone, if you've got some nail varnish remover you could try mixing some with the flux you have already, keep in mind though that they put perfumes and other softeners in nail varnish remover so it wouldn't be the purest of fluxes.
I would just order some Isopropyl, its so handy for other things, Hexa the company I linked don't mess about so it should be with you sharpish.
CNC4YOU is still the best place both on price and service, the motors are of the lowest inductance we can find vs other things, link below.
Link: https://www.cnc4you.co.uk/Stepper-Mo...YGH301B-Nema23Lee
27-07-2017 #5
If you're soldering new components, the flux in common solder should be more than enough to ensure a good solder joint. Any common solder you buy for electronics should be flux cored.
It must be over 10 years since I last used separate flux, and that was dealing with vehicle earth points that had been exposed to a couple British winters. I've certainly never used it on any PCB I've soldered.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
27-07-2017 #6
I have been working with electronics since the mid 70's and as long as I remember, there have ALWAYS been flux in the solder wires I used. I never bought any separate flux ever in my life. As far as I know, flux in liquid or hard form is only used for soldering pipes and other very large surfaces, not PCB.
28-07-2017 #7
So far the only advice he's had is to get a solder sucker and start again, clearly there is more going on than that and he needs more experienced input, let's give him that instead shall we.
Flux cored or not something isn't right and it's probably a combination of things, additional Flux I think will help Ravi along in getting better joints, additional flux has been used in the SMD and rework/reflow arena's for years and for a very good reason!
What solder wire are you using?
Ravi, using additional flux cannot hinder the soldering process and can only assist you in doing a nice/better job, don't tell anyone this but that is the reason they put it in solder wire in the first place :).
Your soldering iron needs to be hot enough, balling up like that can come from the iron being too hot or cold, I'm betting yours is to cold, some lower end irons heat up but they don't do very well at staying hot once you start using them, this happens with low power irons too at around the 25w range, when you are trying to solder bigger components.
However my go to for most jobs is now a 12w Weller SP12, I inherited it along with technique from my grandfather who was a British telecom engineer, the iron is from around the 80-90's and still has the original tip, it along with a combination of technique, additional flux and a solder wire appropriately sized gets everything I solder just right for me - every time...Thanks Granddad!
40-60w is an average range on what allot of irons will be rated at, my other iron is a 25w similar to the Weller, I also have two gas soldering irons for mobile work. The bigger of the gas irons is handy with the tip removed as its basically a mini blow torch and works excellent on heat shrink and those jobs where you need a small flame with a bit more power.
What iron are you using ?
The tip of your iron needs to be "on point" Ravi, the problem comes from oxidation and not keeping your tip clean, once your tip becomes oxidized the solder will no longer want to flow or stick to it properly and this is a problem. Don't clean your tip in flux or water, this shocks the tip and damages the Iron and Chromium plating, just dip the tip in some pure Rosin after each joint and that should be good enough for the tips life time.
Solder to the tip of your iron and then to the area/joint to be soldered, your transferring the solder from one to the other, try and do this with as minimal amount of heat going into your component as you can and your now doing it correctly.
Soldering isn't rocket science Ravi, there are lots of options in terms of tools and technique but a few fundamentals need to be right for it to be successful, if left those balls of solder you've done so far could come lose and as such cause arcing, arcing not only damages components and equipment but it can cause fires too !!!!Lee
3020T Capabilities
By TT901 in forum Chinese MachinesReplies: 6Last Post: 03-03-2017, 04:20 PM -
Chineese 6040 problems
By Kendrick57 in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 18-10-2015, 10:52 PM -
Ballscrew for 3020T Y Axis
By richie00boy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 02-08-2013, 02:47 PM -
A viable mini-ish-mill build, or a hiding to nothing..?
By Wal in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 02-07-2013, 07:33 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
