31-07-2017 #71
The Following User Says Thank You to ravihotwok For This Useful Post:
31-07-2017 #72
31-07-2017 #73
thanks very much lee, still a bit iffy but the main thing is I now know the theory behind it.
Yeah my mate does a lot of contracting to a few aerospace firms and has helped me out a fair bit with advice, nearly pissed himself when I showed him my 4 axis machine lol
02-08-2017 #75
Work has been crazy busy at the moment so only been able to do a little bit on the build. I have started to create an enclosure for the machine, this will consist of a sealed unit with 2 led strip light running at the top of the enclosure front to back each side. One side of the enclosure will be perspex and and front will be a hinged perspex door. There will be an extraction system installed on the side opposite the perspex. Its a very make-shift idea but it will serve a purpose I think and help keep the area as clean as possible.
I have replaced all the wood on the workbench from cheap thin mdf to 12mm thick ply wood for stability, weight and strength.
Now I have added a few coats of paint to the inside of the enclosure to aid lighting
02-08-2017 #76
02-08-2017 #77
One other issue I have is that I now have a additional power supply/controller for my 600w spindle which wont fit within my planet control box. I have decided to fabricate another box lid which will fit and attach to the top of the existing planet box. Here is the grp mould I have made so far to achieve this
Nothing really that interesting and still haven't registered the license correctly since changing from the crap control box to the new one so hopefully I will be able to sort this at the weekend and make some progress on finishing the wiring. All in all enjoying the small amounts of time I spend on this so far which is great. More to come :-)
02-08-2017 #78
Have you had it cutting yet?
02-08-2017 #79
christ no lol
waiting on some more cable track to feed the limit switch cables through, also need to solder the earths onto the motor cables, trying to run the cables as separate as possible hence the additional cable track, once the enclosure is finished I can work out the exact length of the cable so they are as short as possible.
Im not too keen on firing the machine up when its half way through installation as I know I will start making loads of stuff and just make a mess everywhere lol
03-08-2017 #80
3020T Capabilities
By TT901 in forum Chinese MachinesReplies: 6Last Post: 03-03-2017, 04:20 PM -
Chineese 6040 problems
By Kendrick57 in forum Gantry/Router Machines & BuildingReplies: 18Last Post: 18-10-2015, 10:52 PM -
Ballscrew for 3020T Y Axis
By richie00boy in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 02-08-2013, 02:47 PM -
A viable mini-ish-mill build, or a hiding to nothing..?
By Wal in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 02-07-2013, 07:33 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
, your plan for the control box and the earthing looks to be ok.
