  1. Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
    looks like these are the drivers https://planet-cnc.com/product/motordriver-2-5a-32/
    says current selectable.... i would say there is a good chance the current is set too low.
  3. hmm, sounds interesting mate. Is this a variable that is changed via the software or manually on the control board?
    My build blog:
    Chinese 3020t Build
    i would guess a jumper or pot on the board.
  5. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  6. #5
    looking at the pics, you have a little dip switch to choose the micro stepping setting, so chances are the red jumper is your amperage setting.
    edit - infact I think i can make out "Imax" next to the jumper in one pic, so thats almost certainly the puppy. Check what it is set to.
  7. I will go and have a look at my pics now matey
    My build blog:
    Chinese 3020t Build
  8. #7
    Looks like your motors are 2.0A from a quick google (you may want to verify that yourself) so thats the setting you'd want on the drivers
  9. right I understand exactly what you mean, the 4 little boards are the drivers, and there is a jumper on the 2 pins the other side to the 2 pins labelled imax
    My build blog:
    Chinese 3020t Build
  1. 3020T Capabilities
    By TT901 in forum Chinese Machines
    Last Post: 03-03-2017, 04:20 PM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Ballscrew for 3020T Y Axis
    By richie00boy in forum Lead Screws, Nuts & Supports
    Last Post: 02-08-2013, 02:47 PM
  4. A viable mini-ish-mill build, or a hiding to nothing..?
    By Wal in forum Milling Machines, Builds & Conversions
    Last Post: 02-07-2013, 07:33 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
