Thread: EM806 drivers
    Would anyone know if the RS232 cable needed to connect the driver to use Pro-tuner software, could I connect using a RS232 to USB please.
    Phill
    Lives in Marple Stockport, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Phill
    Have you seen this thread as there is some info here :- http://www.mycncuk.com/threads/11007...2492#post92492
    I believe you can get a usb to serial adaptor you might have to reverse the tx and rx connections on the lead.
    Thanks Clive,
    Had not seen the thread, this is what I can get and would like to connect it to a laptop
    Phill
    Thanks Clive,
    Phill
    That looks like a RJ11 to DB9 you would also need something like https://www.amazon.co.uk/USB-RS232-C.../dp/B00077DJIQ
    or similar make sure you get a driver disc with it
    edit you might have to reverse the tx and rx wires as I said in the last post
    As Clive said, you need both the cable you are showing, and a USB to RS232 adapter to plug it in to.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Did'nt really old laptops come with a COM port ?
  1. overcurrent alarm on em806 driver
    By johngoodrich in forum General Electronics
    Last Post: 31-03-2017, 10:01 AM
  2. EM806 vs AM882
    By Ger21 in forum Motor Drivers & Controllers
    Last Post: 27-02-2017, 09:57 PM
  3. Help please - Leadshine EM806 over-current error
    By Noplace in forum Motor Drivers & Controllers
    Last Post: 25-08-2015, 04:02 PM
  4. Which PSU and drivers do I need ?
    By eurikain in forum General Electronics
    Last Post: 18-08-2015, 11:44 AM
  5. Tuning Leadshine EM806 with SY60STH86-3008B
    Last Post: 17-02-2015, 08:18 PM
