08-07-2017 #19
I'd like to get my hands on one to see, but the torque curves look more akin to those of a stepper system, than a servo system. Stepper and brushless motors are very similar, it's just stepper motors are synchronous (which is what gives them the detents), while servos are a/non-synchronous, which means you don't lose power/torque overcoming the detents.
Regarding the Nema 23 v 34 argument. Compare them running similar voltages. You'll generally find Nema 34 graphs are using a high voltage driver, while Nema 23 are done using a relatively low voltage driver.
I've just had a quick look to see if I could find a couple graphs to do a comparison, but the Nema 34 graphs I found were mostly using a 110VAC supply (about 155VDC), while the Nema 23 ones were using 30-40VDC supplies. At those low voltage, torque drop of is very noticeable, and crippling Nema 34s with only 70VDC also makes for a very similar torque drop-off. You need voltage to over come the back EMF at speed. Without that voltage, torque at speed is very limited.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Toolbox Refurb - New Handle Fittings
By Wal in forum Metalwork Project ShowcaseReplies: 4Last Post: 22-09-2016, 10:26 PM -
CONVERSION: Sx2 plus cnc conversion
By Lewywri89 in forum Conversion Build LogsReplies: 11Last Post: 30-11-2014, 11:36 PM -
RFQ: CNC Myford Conversion
By Jconway651 in forum Projects, Jobs & RequestsReplies: 0Last Post: 16-10-2014, 09:52 AM -
CONVERSION: X2 conversion on a budget!
By craigrobbo in forum Conversion Build LogsReplies: 1Last Post: 30-10-2012, 05:00 PM -
Sieg sx2 conversion kit
By Goldigger in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 24-04-2011, 07:42 PM
