09-07-2017 #23
For induction motors, torque remains pretty constant over the rated speed range up to the rated speed, and is a result of the amount of current flowing through the windings. Although frequency controls the speed, as speed drops, the voltage required to drive that current through the windings also drops proportionally I.e. for a 3000rpm 240V motor, peak voltage will be around 120V when running at half speed.
Now because voltage is reduced, so is the power output, so if the above motor was rated at 1KW, at 1500RPM it would only be producing 500W. You could increase current (which some inverters can do to give a low speed torque boost), however you risk overheating the windings due to the extra current.
Above the rated speed/power, current becomes limited. So taking the above example motor, and trying to double it's speed to 6000RPM, you can do so by doubling the frequency, however unless you double the supply voltage, 240V will only be able to force half the current needed to get full torque through the windings, with the result you will only get half the rated torque.
The result is above the rating, the motor becomes power limited. You can have double the speed, but only half the torque, so even though the motor is spinning faster, you still only have 1KW of power.
This is why when fixed speed motors with gearing get replaced, they're often replaced with far bigger motors.
With gearing, say you take a 2Nm 3000RPM (probably about 600W), you gear it down 4:1 and get 8Nm at 750RPM.
To get that same torque at the same speed using direct drive, and still retain 3000RPM, you now need a motor capable of 8Nm and 3000RPM, so you need a motor with 4 times the power. (realistically you'd compromise with some gearing, a bit less torque, and running the motor so higher speeds are above the motor rated speed and into the derated/reduced current area).
That's the reason why most modern CNC machines come with such big spindles. For most end users, it not because they're going to be managing to use upwards of 10KW hogging metal with endmills, it's so they still have enough torque to drive a big facemill at a couple hundred RPM while still taking a decent depth of cut.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following User Says Thank You to m_c For This Useful Post:
Toolbox Refurb - New Handle Fittings
By Wal in forum Metalwork Project ShowcaseReplies: 4Last Post: 22-09-2016, 10:26 PM -
CONVERSION: Sx2 plus cnc conversion
By Lewywri89 in forum Conversion Build LogsReplies: 11Last Post: 30-11-2014, 11:36 PM -
RFQ: CNC Myford Conversion
By Jconway651 in forum Projects, Jobs & RequestsReplies: 0Last Post: 16-10-2014, 09:52 AM -
CONVERSION: X2 conversion on a budget!
By craigrobbo in forum Conversion Build LogsReplies: 1Last Post: 30-10-2012, 05:00 PM -
Sieg sx2 conversion kit
By Goldigger in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 24-04-2011, 07:42 PM
