    I have a comment.
    I have seen credible comments from guys with experience, that the grease used in milling spindles, had great effect.
    Re: heating at higher rpms, power used, etc.
    Like 30-50% of the power went to heat, vs 5%, with better grease.
    And noise decreased 50% or so, by tfar method.
    (That Feels About Right).
    Kluber Isoflex 15 is the gold std, for high end machine tool industrial spindles.
    It is very expensive.
    You need very little, about 1.5 cm3 for a big spindle bearing.
    I bought a 50 gm tube, for 1 micron spindles I am making, 4 of, experimental/commercial test samples, with real abec 9/iso 2, bearings in 25 and 40 mm D.
    I will make 4 test spindles, 2 of 25 mm and 2 of 40 mm, with both bearings, and see how they work.
    Yes, the spindle at 40 mm is now hardened, ground, polished, has 2 microns tir (in spec, just) but I will use a soft lap and diamond paste to reduce the error a bit.
    Anyway, better grease has reportedly made a major difference on spindles.
    If You want some, I am happy to mail some Kluber "unicorn snot value" grease to You, free.
    I doubt the grease has any major effect on accuracy .. but ..
    I think it quite probable, perhaps, the grease can/will point out the next error in the chain.
    Contact me any way You want, if You want to try some.
    One email is greystoneprecision at the google mail dot com.
    I do know for a fact, that modern cnc lathes (tools) use P4 bearings or better, since the packaging on mine says so.
    And my factory training.
    And these bearings do very much benefit from rgw better grease, mostly at higher speeds 2-5k and up.
    Personally, I doubt it matters at low speeds, but think I might well be wrong.
    CNC machining is often about corner cases, and stuff works different to what one might expect.
    The tiny balls in bs supports and nuts actually run really fast at their surface speed.
    Anyway, You want a bit, You can have some.
    No conditions at all.
    Quote Originally Posted by Agathon View Post
    Decided to strip the ball-screws and repack with new balls:
    Hi Hanermo2 and thanks for your very comprehensive and convincing post on your experience of servos. I'm coming to the same conclusion. Steppers are fine for hobby machines, but for anything a bit more industrial a servo is the way to go. Fehlmann certainly dropped steppers within a couple of years and went to servos.
    The Fehlmann is a slightly odd machine in that it's a drilling machine with milling capability - so despite it's industrial specification in terms of mass, the design is a compromise, with milling, and then CNC, as an afterthought. With that said they sold well in their home market. The latest generation of Fehlmann machining centres are built round a conventional square slide-way for the Z axis, but they still produce a manual and semi-cnc/manual version of the Picomax: http://www.fehlmann.com/en/products/...picomaxr-21-m/
    I was interested in what you mentioned about direct drive. When Fehlmann switched to servos (see pic) they mounted the motors remotely - not sure if it's a belt or gear drive, but suspect belt. The latest semi-cnc/manual of the drill mill that I have also has remote servos - I'm not sure about their machining centres.
    Having reassembled the ball-screw, replacing it proved interesting since the nuts, or rather the keys in the nuts, didn't want to go into the key-way. The key-way or the keys were obviously minutely out of line with each other. A rub over a stone got them to slide in, but the results from the screw were disappointing - still not sure why. It could be an alignment issue - which seems strange given the precision nature of the table and the screw, but it's the sort of thing I've regularly encountered with precision machine tools - a lot of fettling takes place when these things are built. Anyway, I decide to but the nuts on the in the original orientation which seems better, but I can't get the backlash better than 0.01 without sacrificing the smoothness of the screw. I will tinker some more today.
    I've had 20 years experience rebuilding machine tools and generally I've found that even if a bearing's tracks look good through a loupe they may well be slightly rough when under load. This is sometimes due to poor fitting (hammering the inner) and tiny imperfections are left on the bearing tracks which will only show up under a microscope. I suspect that the ball-screw and nut assembly have similar issues. I'm not about to replace them so will live with the 10 microns of backlash.
    Thanks for your offer of the Kluber Isoflex. This is a product I'm familiar which since it's specified by some of the manufacturers I deal with. I actually use an SKF LGMT2 which has a similar specification and was more readily available at the time I needed it. In fact the Fehlmann's central lubrication system covers everything from the spindle bearings through to the ball-screws and everything in-between. The Vaseline used was just to get the balls to stick to the nut during assembly - it will soon wash out.
    If you're ever in my "neck of the woods" you'd be more than welcome to visit.
    I forgot to say that it would be nice to see a photo or even a video of you CNC machine(s).
    David
    I have some parts from an older machine looks like PICOMAX100 that was being disposed of by a machinery dealer .
    It used sevo motors and timing belts to drive the ball screws .
    when I arrived the controls had been chucked in a skip , the sevos removed and the intention was to strip the rest to get rid of the 3000 K that was in the way .
    I still have the sevos , the SF 32 spindle , some SF30 tooling , the roller slides , massive leadscrews ( maybe 30mm ) with ball nuts and bearings .
    So true sevos when others used steppers ! - well as you say , it IS Swiss.
    Quote Originally Posted by C1Geoff2020 View Post
    What a shame it was scrapped - I would have considered buying it.
    I've only just started working on the old Fehlmann again after a couple of years of inactivity. My machine is a pain as it was originally only two axis. The Picomax 100 was a three axis machine that used the quill rack and pinion driven from a worm and wheel belt driven from a servo as the Z axis. It sounds like a terrible idea when one thinks about the average drilling machine rack and pinion, but being Swiss there's virually no backlash. As I mentioned earlier in this thread, the extremely clever engineer I bought the machine from had made a worm and wheel drive (the aluminium housing seen on the right hand side) to drive the pinion. However, I have found that because he used a fully throated worm wheel it has been almost impossible to remove the backlash.
    I will probably end up using a ball-screw to move the quill, but I have recently reinstated the machine's original worm and wheel drive (which employs a gashed bronze worm wheel) and have backlash of about 0.01mm - not bad. I shall see how it works in practice once I have mounted the stepper motor to the original 90º cross-helix gear drive to the worm shaft. There is significant backlash in this gear, but it will be unimportant in terms of the ability of the quill to remain in position because of the worm and wheel - the backlash is constant so it can be accounted for in the software. As I say, this is almost identical to how it was originally done on the three axis machines, however, it has proved difficult to employ a belt drive to the worm shaft due to differences in the head castings - see drawings.
ID:	27453   Click image for larger version.
ID:	27454   Click image for larger version.
    Attached Files Attached Files
    I should have said Geoff, if you want to sell any of the Fehlmann bit - especially the SF32 - tooling let me know. I've PMed you.
    David
  1. Toolbox Refurb - New Handle Fittings
    By Wal in forum Metalwork Project Showcase
    Last Post: 22-09-2016, 10:26 PM
  2. CONVERSION: Sx2 plus cnc conversion
    By Lewywri89 in forum Conversion Build Logs
    Last Post: 30-11-2014, 11:36 PM
  3. RFQ: CNC Myford Conversion
    By Jconway651 in forum Projects, Jobs & Requests
    Last Post: 16-10-2014, 09:52 AM
  4. CONVERSION: X2 conversion on a budget!
    By craigrobbo in forum Conversion Build Logs
    Last Post: 30-10-2012, 05:00 PM
  5. Sieg sx2 conversion kit
    By Goldigger in forum Milling Machines, Builds & Conversions
    Last Post: 24-04-2011, 07:42 PM
