    Swiss backlash 0.01 mm new ??
    I would have expected your picomax to have zero to 0-1-2 microns backlash.
    I suspect the bs fixed end bearings are not properly adjusted/preloaded, or ..
    .. your ballnut is loose/failed somehow and has no preload.
    Easy enough to test.
    Dti screw end, while loading back/forth with a prybar of some type, separately on screw end and on nut end/assy.
    One should have a major deviation vs the other.
    Quote Originally Posted by Agathon View Post
    Spent the evening trying different permutations of the ball-nut assembly and the best I can achieve on both axes is 10 microns. If this were a conventional manual machine I'd be overjoyed with 4 tenths of a thou! In fact the very expensive Swiss machines that I sell have a backlash from new of around 0.01-0.02 mm.
    Anyway, the machine is running very nicely and the back-lash compensation on Mach3 is working well.
    As I frequently say to my customers "it's a metal cutting machine not a grinding machine" so I don't expect nor want to machine to tolerances better than +/- 0.005. I certainly don't think it will be a problem in respect of climb milling.
    More soon...
    I've checked everything and it's all correctly adjusted - first thing I thought of was movement in the pillow-block bearings but there's no movement here. If I take the ball-nut preload one increment higher on the vernier the screws become notchy. It's probably just down to wear and tear. We'll see what the performance is like in practice.
    You are being very vague, is this sprung or a simple crush?
    Crush.
    It was a bit of a bodge springing mine, I added a spacer and 2 Belleville washers. Well 6 spacers and 12 washers to do all the bearings and nuts. But the reward was out of all proportion to the effort.
    So, if I'm interpreting that correctly, you have a double ball-nut set-up like my machine?
    I could do something like this although it would mean making a new retaining flange. I have to say that apart from grinding spindles, I'm not a fan of spring-loaded solutions. I'm also not convinced that backlash of 0.01 is much of an issue. My conventional mill has about 0.25 backlash and it's only a problem with heavy climb-milling or slot milling and then it can be overcome by reducing the feed rate and the depth of cut. Mind you the table and slide alone must way 200kg - mass helps, as do well adjusted gibs.
    I meant to have asked what the rest of you mill consists of Robin - got any pics?
    I don't have a recent pic, here's an old one...
  1. Toolbox Refurb - New Handle Fittings
    By Wal in forum Metalwork Project Showcase
    Last Post: 22-09-2016, 10:26 PM
  2. CONVERSION: Sx2 plus cnc conversion
    By Lewywri89 in forum Conversion Build Logs
    Last Post: 30-11-2014, 11:36 PM
  3. RFQ: CNC Myford Conversion
    By Jconway651 in forum Projects, Jobs & Requests
    Last Post: 16-10-2014, 09:52 AM
  4. CONVERSION: X2 conversion on a budget!
    By craigrobbo in forum Conversion Build Logs
    Last Post: 30-10-2012, 05:00 PM
  5. Sieg sx2 conversion kit
    By Goldigger in forum Milling Machines, Builds & Conversions
    Last Post: 24-04-2011, 07:42 PM
