I've checked everything and it's all correctly adjusted - first thing I thought of was movement in the pillow-block bearings but there's no movement here. If I take the ball-nut preload one increment higher on the vernier the screws become notchy. It's probably just down to wear and tear. We'll see what the performance is like in practice.
17-07-2017 #2
You are being very vague, is this sprung or a simple crush?
17-07-2017 #3
17-07-2017 #4
17-07-2017 #5
So, if I'm interpreting that correctly, you have a double ball-nut set-up like my machine?
I could do something like this although it would mean making a new retaining flange. I have to say that apart from grinding spindles, I'm not a fan of spring-loaded solutions. I'm also not convinced that backlash of 0.01 is much of an issue. My conventional mill has about 0.25 backlash and it's only a problem with heavy climb-milling or slot milling and then it can be overcome by reducing the feed rate and the depth of cut. Mind you the table and slide alone must way 200kg - mass helps, as do well adjusted gibs.
I meant to have asked what the rest of you mill consists of Robin - got any pics?
17-07-2017 #6
17-07-2017 #7
Toolbox Refurb - New Handle Fittings
By Wal in forum Metalwork Project ShowcaseReplies: 4Last Post: 22-09-2016, 10:26 PM -
CONVERSION: Sx2 plus cnc conversion
By Lewywri89 in forum Conversion Build LogsReplies: 11Last Post: 30-11-2014, 11:36 PM -
RFQ: CNC Myford Conversion
By Jconway651 in forum Projects, Jobs & RequestsReplies: 0Last Post: 16-10-2014, 09:52 AM -
CONVERSION: X2 conversion on a budget!
By craigrobbo in forum Conversion Build LogsReplies: 1Last Post: 30-10-2012, 05:00 PM -
Sieg sx2 conversion kit
By Goldigger in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 24-04-2011, 07:42 PM
