    You are being very vague, is this sprung or a simple crush?
    Crush.
    It was a bit of a bodge springing mine, I added a spacer and 2 Belleville washers. Well 6 spacers and 12 washers to do all the bearings and nuts. But the reward was out of all proportion to the effort.
    So, if I'm interpreting that correctly, you have a double ball-nut set-up like my machine?
    I could do something like this although it would mean making a new retaining flange. I have to say that apart from grinding spindles, I'm not a fan of spring-loaded solutions. I'm also not convinced that backlash of 0.01 is much of an issue. My conventional mill has about 0.25 backlash and it's only a problem with heavy climb-milling or slot milling and then it can be overcome by reducing the feed rate and the depth of cut. Mind you the table and slide alone must way 200kg - mass helps, as do well adjusted gibs.
    I meant to have asked what the rest of you mill consists of Robin - got any pics?
    I don't have a recent pic, here's an old one...
    Very neat, especially the Z axis. Wouldn't mind seeing some details of this as I'm sure I'm going to have to go down this route eventually.
    What sort of backlash have you achieved on the x and y?
    There's a build log from many years ago, I will try and link it...
    http://www.mycncuk.com/threads/651-W...ht=Warco+Major
    I fitted zero backlash double nuts, big disappointment, so I sprung them and it was like magic.
    The springs mean that I have no backlash up to 1/4 ton but if I ever pass that loading presumably everything will go horribly wrong.
    I do get some sideways slop in the quill if I forget to pack it out with thick, icky grease. Open to suggestions.
    Quote Originally Posted by Agathon View Post
    I meant to have complimented you on the really super job you've done on the casings for the drives - very professional.
  1. Toolbox Refurb - New Handle Fittings
    By Wal in forum Metalwork Project Showcase
    Last Post: 22-09-2016, 10:26 PM
  2. CONVERSION: Sx2 plus cnc conversion
    By Lewywri89 in forum Conversion Build Logs
    Last Post: 30-11-2014, 11:36 PM
  3. RFQ: CNC Myford Conversion
    By Jconway651 in forum Projects, Jobs & Requests
    Last Post: 16-10-2014, 09:52 AM
  4. CONVERSION: X2 conversion on a budget!
    By craigrobbo in forum Conversion Build Logs
    Last Post: 30-10-2012, 05:00 PM
  5. Sieg sx2 conversion kit
    By Goldigger in forum Milling Machines, Builds & Conversions
    Last Post: 24-04-2011, 07:42 PM
