Thread: DIY Lathe - What Headstock?
Have you got a lathe or access to one?
What kind of tolerances can Thor produce?
Given the effort you put into Thor, I cant wait to see what you come up with this time for a lathe, tool turret on the cards?Lee
04-07-2017 #2
I have my Emco 120 which Ill sell. Just not big enough for what Id like to do.
Tolerances, not checked yet, should be doing some calibration cuts this weekend once I get a new table installed. I'm also aware that I have a slight offset in my Z axis, getting a bit of deviation across the Y plane, when measuring Z movement. This is due to the spindle clamp I am using, Ill probably replace it or machine something better than what I bought.
I have two main options for a lathe. One, use my massive metal structure that I used for referencing as the base for the lathe, simply bolt rails to its one side, install 3 carts each side, fabricate a simple X and Z Table. Toolchanger, multiple options, id possibly got for a non turret option as its easier (I think) based on a large working area.
The idea is that I get a headstock that I can then just add a nice high power servo motor to and go from there.
Another option is to form and cast another concrete structure but this is a lot more work. I may start with the metal structure, prove the concept, then convert it to Concrete (or make another a decommission this one).Last edited by Chaz; 04-07-2017 at 01:52 PM.
04-07-2017 #3
Depends on what you will use it for. Have you thought of indexing and lather 4rth axis, all in one? LIke this one . basically that guy has his build log on the cnczone
http://www.theinturn.com/Last edited by Boyan Silyavski; 04-07-2017 at 09:13 PM.
04-07-2017 #4
04-07-2017 #5
Bicycle disc brakes, some aluminum, 700w servo motor , you machine the pulleys and so, some belts. So basically the extra controller may be or you figure another way to do it.
I find that really an useful thing to haveLast edited by Boyan Silyavski; 04-07-2017 at 09:16 PM.
04-07-2017 #6
04-07-2017 #7
As far as i remember 7:1 ratio of a 700w servo motor. Hydraulic bicycle brake brakes and fixes at certain position when indexing. Bearings are fairly simple. They are so cheap now. Something like the rotating ball nut. A pair of oposing angular contact bearings with sufficient size. Thats it
04-07-2017 #8
Check his channel on you tube. There are 10 or so videos where he explains everything in detail https://www.youtube.com/user/Simpsons36/videos
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
04-07-2017 #9
PRICING:
InTurn™ MEGA Duty 4th axis US$ 2,950
InTurn™ ULTRA Duty 4th axis
Sealed Ball bearing model US$ 3,795 (introductory price)
InTurn™ Ultra-T
Tapered Roller Bearing model US$ 4,995 (Introductory price)
InTurn™ Tail Stock II US$1,495
CNC style lathe home brew Lathe for drilling and cutting.
By Bodge in forum Lathes, Lathe Rebuilding & ConversionsReplies: 9Last Post: 18-04-2012, 10:45 AM
