    so, IF its a plasma table and only pulling round a torch.
    do you get racking?
    want to use an oem linear stage thing as x
    driven from one side, rail on the other
    stupid idea?
    or do I simply lay down two and drive both motors on the same drive
    Lives in Marple Stockport, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I think you need to state the size of the machine, driving anything is not going to be good from one side. you could use a long belt between them or two motors and two drives
    hello, the picture gantry/axis
    about 40 inches
    will buy three 40 inches long...
    two for x one about the same size for y
    a tiddler for z
    do I link them with a belt or drive both x axissss
    I have to use modular bits and bobs so it becomes portable
    I wouldn't drive anything from one side personally no matter what the machine is. Out of interest have you seen it done somewhere?
    For plasma cutting forces are not there and as long as bearings under gantry have a fair spacing I don't see that it would rack in that sense (bind up)
    But inertia forces are there. So rapid changes of direction on the gantry would start to give a bit of lag on the non driven side which means slight out of position cut. Question is whether this error would be large compared to kerf - someone who has used plasma more recently than me may be able to answer that one.
    I would slave both sides or drive both sides direct.
    Quote Originally Posted by nobby View Post
    about 40 inches
    a tiddler for z
    Personal I wold use slaved motors as already been said. simples
    I think he is talking about the portable plasma machines like on video. But as a portable machine, this is not a do all one. It just serves specific purpose . Anyway, plasmas have to be fast, so as other said, No, make a proper 2 side driven one
    There have been many single sided drive plasma machines in the past but these were industrial machines and very well built with servo drives via gearboxes to rack and pinion drive on rail tracks. I think the widest machine I worked on would have been between 3 and 4 metres wide. Some had single heads and some with two. Twin drive machines are better and can move faster but then again cost more.
    Yes, it really just depends on how rigid the machine is.
    We have a Morbidelli router with a cantilevered gantry, that's only attached at 1 side. It has no trouble cutting through 30mm particle board in one pass at 25m/min
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Nice addition Gerry. I forgot about the routers. We also have a scm router at work. Single side drive cantilever machine. Nice piece of engineering.
  1. Double side machine a small part
    By timtom1 in forum Woodwork Discussion
    Last Post: 12-03-2015, 07:30 PM
  2. Drilling/tapping in ends/side of aluminium plate
    By matt-b2 in forum Metalwork Discussion
    Last Post: 13-01-2015, 01:31 PM
  3. RFQ: Gantry side panels
    By fvfdrums in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 03:50 PM
  4. Preventing racking?
    By cncbobuk in forum Gantry/Router Machines & Building
    Last Post: 26-08-2013, 08:03 PM
  5. Help understanding the software side of cnc routing.
    By don_jarr in forum CAD & CAM Software
    Last Post: 23-06-2011, 01:13 PM
