    Hi everyone.
    I am Nick from Greece.
    I want to warn every member that this thread might contain very silly and hundred time answered questions.
    I am an aircraft engeener and maniac selfbuildingmyownstupidthings guy! resently , one year ago, I enter the world of cnc, I bought a new old stock desktop cnc with cutting area 420mmX320mm and replace the motors,controllers and interface in order to make it work.
    Υesterday that cnc went to a new house,with the money I get and some designing help from a friend that design 3D printers, I will start soon my cnc router build.
    The idea is to build a machine with external dimensions 1500x800mm, steel frame (to lower the cost) two motors at Y axis one at X one at Z, the purpose of the machine will be woodworking and mild metal cutting.
    The friend-designer suggest the design below, I know that this is something it has been used at the past at MechMate machines but I do not know if there are any disadvantages since this is not a design that I usually see, what do you guys think?
    Another question has to do with the ball screw according to their length, I am thinking to use 1610 ballscrews am I going to have any problem at Y axis since this is going to be the longer one?
    Motors are going to be steppers, Nema 34 637oz for X, two Nema 34 1204oz for Y and one Nema 24 566oz for the Z, any suggestions and thoughts are welcome.
    Cheers, Nick!
ID:	21463   Click image for larger version.
  1. First cnc build drive advice needed
    By threedee in forum Gantry/Router Machines & Building
    Last Post: 25-05-2016, 11:12 PM
  2. Build log. Design advice needed.
    By eurikain in forum Gantry/Router Machines & Building
    Last Post: 25-06-2015, 06:53 PM
  3. BUILD LOG: my router build - advice needed
    By thomashomer1986 in forum DIY Router Build Logs
    Last Post: 02-12-2013, 11:45 PM
  4. BUILD LOG: New cnc router build looming, advice needed
    By Mad Professor in forum DIY Router Build Logs
    Last Post: 06-11-2012, 08:12 PM
  5. new mashine build advice needed
    By Finrod in forum Milling Machines, Builds & Conversions
    Last Post: 14-10-2008, 11:05 PM
