Well, I did the thermal treatment on Y and it didn't overheat and the heatsink got a lot hotter, which is great. I then did the same job on the other axes and put them all back (in different order, probably), this time the Z failed. Now I've heat-treated a spare and swapped that in, so trying again.
Ultimately I'd like to actually buy a real TB6600 controller and try that, anyone know of a good supplier for those? Not seen one in the UK yet that looks pucker, but Far East will do!
Thanks,
Phil
23-01-2018 #2
Phil,
These are the ones that I bought...
https://www.ebay.co.uk/itm/Single-Ax...vbgiYCPuIMIsVA
Although my seller went under the name of "bigger*gift", but we all know the Chinese are a little agile with their naming. I think the discriminator is the 50V and 5A rating.
I'd caution, however, the subject of this thread and that mine, bought April/17 required the opto-isolators replacing.
23-01-2018 #3
OK thanks, I just bought two that look just like that, with the higher voltage and current rating. I can replace the optos as this thread details.
Meanwhile, I just ran a large job at 2x speed and it made it through the job twice without tripping, so maybe I'll be OK for milling polystyrene - will wait a while before putting the actual lump of wood under it though!
-Phil
TB6600 vs. CW5045
By eurikain in forum Motor Drivers & ControllersReplies: 0Last Post: 04-10-2015, 12:23 PM -
How hot do TB6600 drivers run normally ?
By KevinK in forum Motor Drivers & ControllersReplies: 4Last Post: 20-09-2015, 03:50 PM -
Pcb-linear motion solutions
By kyris31 in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 20-02-2013, 10:14 AM -
The reason of noise of Engraving machine and solutions
By Tomas in forum Machine DiscussionReplies: 0Last Post: 26-08-2011, 10:41 AM -
Delcam Advanced Manufacturing Solutions
By Andywarwick in forum Manufacturer NewsReplies: 0Last Post: 06-06-2011, 04:48 PM
