Page 6 of 8 FirstFirst ... 45678 LastLast
  1. #51
    Thats what i did , my beast did not like even 6m cables so i had to make 10m some of them using the TME cables, which honestly for 2euros per meter are incredible deal. They have all possible connectors too
    I'd forgotten that you mentioned tme.eu. At 2 Euro a metre they're a no-brainer.
  2. #52
    If I read it right, Gary would do me a set of three 400W motors and drivers for £1260 + tax. That doesn't sound too awful but I know nothing about servo motors. I'm not shopping, just cogitating.
  3. #53
    Lives in East Lothian, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    The time component of making cables is very often overlooked.
    For a hobbyist it's not normally a problem spending a few hours finding the connectors/cable/wiring diagram and physically making the cables, but when time is money, pre-made cables are cheap.
    All my servos have been bought from Gary/Zapp. Certainly not the cheapest option, but he's not just a box shifter, and should you need any advise, he's only an email/phone call away.
    One thing to bear in mind, is servos should be inertia matched to their load for best performance. Too big or too small a servo for any given load will not give a good tune. The spindle on my mill demonstrates that perfectly. It's a 110 frame medium inertia servo, and the best positional accuracy I can get before things go unstable is about 200 encoder counts, as it's not got enough of a load to help stabilise it. My lathe on the other hand, which has small inertia 60/80 frame servos, holds sub 20 counts without any problem, as the servo load is a good match to provide stability.
  4. #54
    I plan on making my own servo cables, mainly due to the issue of the available pre-made cable lengths.
    Most come in 3, 5, or 10m lengths. When you get to just over 5m, you can end up with a lot of unused cable length. But is you're needs are close to the pre-made lengths, you won't save much at all making your own.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  5. #55
    servos should be inertia matched to their load for best performance... the best positional accuracy I can get before things go unstable is about 200 encoder counts
    To a lay idiot like me, you seem to be saying that there is some complicated matching that needs to be done on each axis before purchasing a servo system to avoid it being a huge disappointment. My steppers suddenly start to seem like God's gift to His chosen few. Am I misunderstanding?
  6. #56
    Just a bit maybe. I went from steppers to servos and dont think i will ever look back. The other day i had here a vinyl plotter, was looking to buy. What stopped me was it was not servos but steppers, and somehow the noise put me off.
    I got help from knowledgeable members of forum at the time which did the calcs for me what i need for my machine. So 100% here people will help you. Now i know more and can do that myself but surely will ask for advice if i am not sure. That's what the forum is for.
    Anyway, as i have concluded many times, servos are a must for a metal working machine, production machine and hi resolution micro mill. All else could be done from steppers
    PS. what put me off for the plotter was not only the noise but the ability of the plotter to track correctly longer lengths of vynil, if it was servo
    Just apply some common sense. Don't go bolting a high inertia motor to a X1, and don't try using a small inertia servo on a quarter ton table. Use something a reasonable size.
    Given what Agathon has posted links to, I would of though 400 or 750 watt servos would work nicely.
    The smaller machine you've posted a photo of, I would of thought 200 or 400 watt.
    To give some idea, IIRC Denford Triacs with servos, came with 200W servos, however they'd be conservatively sized due to being aimed at education. They perform well enough, however 400W would give a good boost to performance and work just as well.
  8. #58
    Yes, I think the 200W Omron drivers I've just bought will be too small, but will try them geared at 3:1. They were very cheap, so I'm not worried if I have to put them back on the market. I shall be keeping an eye out for 400W which is what they currently fit to the very slightly larger version of my machine.
    Do you know what the ratio was on the Triac servos?
  9. #59
    Quote Originally Posted by Agathon View Post
    I am moving a 200kg gantry with 2x400w servos / via rotating nuts which have smaller inertia than spinning a screw / 3000 mms2 acceleration and judjing from the servo tuning and initial calculations, its the perfect thing. Exact sizing. geared 1.5, not 3. So with 200W servos geared 1.5 you could do a lot of things. No need to gear them up so if not needed. As gearing up will increase the spinning mass so maybe you will not benefit as you think ... 20/30 tooth is an ideal relation and pulley size. For lighter load you could go down as 16t but mind the servo shaft size. I would say for 200W servos, 18t pulley will be right, start thinking from there...
    I am not sure also how Chinese servos stand up to brand servos. If 400w is 400w really? What i know is that the brand servos stand up to what they say. Thats why i preferred 230V AC servos , for all that benefits. If i buy a chinese servo i will always Up it one level of power so just to be sure. 750W isntead of 400
    I think it was Calcomp had the patent on using grit for the driving rollers and everyone else looked jealous. I used to repair these things, a long time ago
  1. CS-LAB AC-servos + SIMdrive
    By blim in forum Stepper & Servo Motors
    Last Post: 20-02-2017, 12:52 PM
  2. Novice- need buying advice
    By davespg996 in forum New Member Introductions
    Last Post: 09-02-2017, 11:12 AM
  3. Advice on Buying a Benchtop CNC
    By Richb in forum Marketplace Discussion
    Last Post: 27-06-2016, 06:43 PM
  4. Mitsubushi Servos
    By Chaz in forum General Electronics
    Last Post: 24-04-2016, 08:08 PM
  5. Machine Buying advice
    By jrob3rts in forum Marketplace Discussion
    Last Post: 17-09-2010, 04:59 PM
