Page 7 of 8 FirstFirst ... 5678 LastLast
  1. #61
    Lives in East Lothian, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Quote Originally Posted by Agathon View Post
    Do you know what the ratio was on the Triac servos?
    I've only got the parts list for the stepper version, and it uses 12:30. Chaz has a servo version, but I don't think there would be much room to go for a higher ratio.
  2. #62
    What size timing pulleys would you suggest for 200 or 400 watt servos? I was thinking that 5M 9mm wide belt should be about right. Centres should be around 100mm.
  3. #63
    I'd say 15mm belt width minimum.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  4. #64
    If you download the Gates DF software, it will generate suitable drive options.
  5. #65
    Just in case you helpful fellows haven't seen my new thread on trying to connect up the drivers to the BOB - here it is: http://www.mycncuk.com/threads/11159...ut-board-Mach3
  6. #66
    Hi guys, I'm going to build a machine to drill and tapping one part, I'm thinking use a servo for tapping and a regular spindle for drilling. Using a regular servo I can do rigid M3 tapping on 2mm aluminium sheet? Have anyone experience with something similar? Tks
    Enviado de meu Redmi Note 4 usando Tapatalk
  7. #67
    Quote Originally Posted by lp_felix View Post
    To do rigid tapping you will need a quadrature encoder on the servo and some thing like Linuxcnc to control it.
    Here is a link in Portugal where you can buy the Mesa cards 6i25 with 7i77 bob will do it.
    Are you think of having the spindle and servo on the same gantry?
  8. #68
    You can also do rigid tapping with UCCNC, and with Mach3/4 with the right motion controller.
    Gerry
  9. #69
    Yes, spindle and servo on same gantry.. Ok, I have a lot of questions but i will study quadrature encoder and servo first, and do stupid questions later.. Thank you for the help.
  10. #70
    Hi Ger21, in fact I planing use uccnc. I have a spare Uc300 5lpt (from other unfinished project) I will read the manual.
    Thanks for the tip.
  1. CS-LAB AC-servos + SIMdrive
    By blim in forum Stepper & Servo Motors
    Last Post: 20-02-2017, 12:52 PM
  2. Novice- need buying advice
    By davespg996 in forum New Member Introductions
    Last Post: 09-02-2017, 11:12 AM
  3. Advice on Buying a Benchtop CNC
    By Richb in forum Marketplace Discussion
    Last Post: 27-06-2016, 06:43 PM
  4. Mitsubushi Servos
    By Chaz in forum General Electronics
    Last Post: 24-04-2016, 08:08 PM
  5. Machine Buying advice
    By jrob3rts in forum Marketplace Discussion
    Last Post: 17-09-2010, 04:59 PM
