Thread: Advice on buying servos.
22-07-2017 #11
The time component of making cables is very often overlooked.
For a hobbyist it's not normally a problem spending a few hours finding the connectors/cable/wiring diagram and physically making the cables, but when time is money, pre-made cables are cheap.
All my servos have been bought from Gary/Zapp. Certainly not the cheapest option, but he's not just a box shifter, and should you need any advise, he's only an email/phone call away.
One thing to bear in mind, is servos should be inertia matched to their load for best performance. Too big or too small a servo for any given load will not give a good tune. The spindle on my mill demonstrates that perfectly. It's a 110 frame medium inertia servo, and the best positional accuracy I can get before things go unstable is about 200 encoder counts, as it's not got enough of a load to help stabilise it. My lathe on the other hand, which has small inertia 60/80 frame servos, holds sub 20 counts without any problem, as the servo load is a good match to provide stability.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
CS-LAB AC-servos + SIMdrive
By blim in forum Stepper & Servo MotorsReplies: 0Last Post: 20-02-2017, 12:52 PM -
Novice- need buying advice
By davespg996 in forum New Member IntroductionsReplies: 1Last Post: 09-02-2017, 11:12 AM -
Advice on Buying a Benchtop CNC
By Richb in forum Marketplace DiscussionReplies: 12Last Post: 27-06-2016, 06:43 PM -
Mitsubushi Servos
By Chaz in forum General ElectronicsReplies: 0Last Post: 24-04-2016, 08:08 PM -
Machine Buying advice
By jrob3rts in forum Marketplace DiscussionReplies: 0Last Post: 17-09-2010, 04:59 PM
