    Lives in East Lothian, United Kingdom. Last Activity: 5 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Quote Originally Posted by Agathon View Post
    Do you know what the ratio was on the Triac servos?
    I've only got the parts list for the stepper version, and it uses 12:30. Chaz has a servo version, but I don't think there would be much room to go for a higher ratio.
    What size timing pulleys would you suggest for 200 or 400 watt servos? I was thinking that 5M 9mm wide belt should be about right. Centres should be around 100mm.
    I'd say 15mm belt width minimum.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    If you download the Gates DF software, it will generate suitable drive options.
    Just in case you helpful fellows haven't seen my new thread on trying to connect up the drivers to the BOB - here it is: http://www.mycncuk.com/threads/11159...ut-board-Mach3
    I suggest you take the advice of the guy who didn't know what a harmonic drive was and couldn't be arsed to look it up before being clever about being wrong :D
  7. I know what a harmonic drive gearbox is, i was just incorrect on the technical term used to describe them. I was selling them 15 years ago, but made by spinea.
  8. The Following User Says Thank You to Gary For This Useful Post:
  1. CS-LAB AC-servos + SIMdrive
    By blim in forum Stepper & Servo Motors
    Last Post: 20-02-2017, 12:52 PM
  2. Novice- need buying advice
    By davespg996 in forum New Member Introductions
    Last Post: 09-02-2017, 11:12 AM
  3. Advice on Buying a Benchtop CNC
    By Richb in forum Marketplace Discussion
    Last Post: 27-06-2016, 06:43 PM
  4. Mitsubushi Servos
    By Chaz in forum General Electronics
    Last Post: 24-04-2016, 08:08 PM
  5. Machine Buying advice
    By jrob3rts in forum Marketplace Discussion
    Last Post: 17-09-2010, 04:59 PM
