Thread: V Cutting Tape
    This application is for a "V" cutting bit. Not sure if there is a downcutting option. I normally use downcutters for pocketing.
    Only option seems to be what was already mentioned- incompatible paints.
    What if you paint top layer with automotive/car type solvent based paints, then engrave, then paint recesses with water based paint that can wipe off the top layer? Might even be able to laquor top layer, possibly even with a silicone product that is totally hydrophobic.
    Currently doing just that, with water based acrylics for the infills.
    For the infills as you call them I think you should use a thick paint because as Boyan said earlier, it will soak sideways into the top grain if thin.
    Also I'm wondering about the stuff they 'wrap' cars etc. in ?
  1. masking tape for engraving
    By universally in forum General Discussion
    Last Post: 02-03-2016, 06:00 AM
  2. V fold Tape
    By orangeart in forum General Discussion
    Last Post: 11-02-2016, 07:16 AM
  3. Double sided tape
    By racerbear02 in forum Woodwork Discussion
    Last Post: 28-02-2015, 07:52 PM
  4. Double sided tape
    Last Post: 22-12-2014, 03:36 PM
  5. Accurate Tape Measure?
    By Tenson in forum Tool & Tooling Technology
    Last Post: 26-05-2012, 04:41 PM
