Thread: Emco 120 cnc lathe retrofit
Well done on your retrofit. I am trying to convert a Leadwell lathe using the SZGH control. I also need to convert my turret signals from PNP to NPN. I have a ULN2803a Chip and also a complete board with the chip. In the SZGH manual, they are very clear that we do not supply 24v to the inputs on the control. When playing with the board on the bench I always have the ULN2803a chip go high to 24v when not taking the input to 0v. Did you also have this issue? Would it be possible to send me your circuit diagram of the converter you used? Thanks
08-05-2022 #2
Hi and thank you. I’ll look at my records for the diagrams if I still have them. In hindsight I would have purchased the auxiliary input output board from szgh, it has all of the connections made for you, and also helps with the tool changer iirc. Send them an email before you decide to diy it..
Regards
FOR SALE: Bridgeport retrofit
By drumsticksplinter in forum Items For SaleReplies: 2Last Post: 09-05-2016, 11:32 PM -
Conect 121 Retrofit
By Sooty in forum Lathes, Lathe Rebuilding & ConversionsReplies: 3Last Post: 17-02-2015, 11:45 PM -
WANTED: EMCO Lathe Tool Changer
By Pete92 in forum Items WantedReplies: 0Last Post: 01-10-2013, 10:27 AM -
REBUILD: StrikeCNC Machine - My Retrofit
By Shinobiwan in forum DIY Router Build LogsReplies: 73Last Post: 19-04-2013, 07:38 PM -
Boxford 125 CNC retrofit advice
By pneanvil in forum Boxford LathesReplies: 4Last Post: 05-12-2012, 11:47 PM
