Thread: Stepper Motor Wiring
14-07-2017 #1
Hello,
I am having to rewire my stepper motors, the motors themselves have 4 wires:
red
yellow
blue
green
Are these all the same on each motor? Im just not sure which pins to wire them too on the control box you see
14-07-2017 #2
not always the same I'm afraid. I've had to switch single pairs of wires around before.
Do you have a model number on the stepper so you could google search a manual?
14-07-2017 #3
Manual? christ chance would be a fine think lol.
Motors have this labelled on them:
Anchuan
57HD0401-15SB
1.8 2OA N1606
Will it do any damage to the circuitry in the control box or the stepper motor if I just try trial and error ? or would it be impossible to work out?
Do you own a multimeter?
You just need to match your pairs really then polarity can be trial and error... see this guide here if you need help with how to do it:
http://42bots.com/tutorials/stepper-...wiring-how-to/
The Following User Says Thank You to Zeeflyboy For This Useful Post:
14-07-2017 #5
Mate that is very very helpful. Im just trying to sort some 4 core cable out from somewhere then I will get investigating.
Cheers pal
14-07-2017 #6
No problem.
Just actually found this which is perhaps a slightly clearer explanation (especially regarding direction) and gives some other techniques if you lack a multimeter... though I'm not sure I would trust the complete trial and error one with expensive drivers/motors, but that's just my paranoia probably!
http://reprap.org/wiki/Stepper_wiring
14-07-2017 #7
you need to use a multimeter ( or a simple battery & bulb continuity tester )to confirm which two wires goes to each motor winding
if you find you have 3 ohms or so between the red & yellow wires connect them to A+ and A- on your driver
you should then find you that you have 3 ohms or so between the
blue & green wires which you should connect them to B+ and B- on the stepper driver
not all stepper drivers have the required fault protection to survive any connection between the A & B terminals
if you find the motor runs the wrong way you can either change it in the controllers software - eg mach 3 changing the direction pin from active high to active low
or
reversing the wires on one winding
eg
changing from
red to A+ and yellow to A-
to
red to A- and yellow to A+
JohnLast edited by john swift; 14-07-2017 at 10:34 PM.
The Following User Says Thank You to john swift For This Useful Post:
15-07-2017 #8
Take any 2 wires from the 4 and cross them together and try and turn the motor shaft. When you feel resistance you have a matched pair. (The stepper's are working as a generator)
Then wire 2 pairs next to each other in the 4 pin connector.
Try it if the motor's run the wrong way either swap the wires around or change the setting in the firmware to invert axis.Last edited by Desertboy; 15-07-2017 at 10:33 AM.
The Following User Says Thank You to Desertboy For This Useful Post:
17-07-2017 #9
thanks very much, very helpful, also is this cable ok to use for my wiring:
http://uk.rs-online.com/web/p/multic...cable/6604037/
17-07-2017 #10
I would go for a screened cable like 4 core CY. https://quickbit.co.uk/Cable/CY-Cabl...-0-75mm-4-core
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Stepper motor tunning wiring
By handyoodman03 in forum Stepper & Servo MotorsReplies: 47Last Post: 11-01-2013, 05:49 PM -
CY or SY cable for stepper motor wiring?
By Jonathan in forum General ElectronicsReplies: 6Last Post: 26-09-2010, 06:25 PM -
Stepper motor wiring
By Buba b in forum Stepper & Servo MotorsReplies: 5Last Post: 28-03-2010, 06:16 PM -
Stepper Motor Wiring (Screened?)
By pequod in forum Stepper & Servo MotorsReplies: 19Last Post: 03-08-2009, 10:15 AM
