  1. Hello,
    I am having to rewire my stepper motors, the motors themselves have 4 wires:
    red
    yellow
    blue
    green
    Are these all the same on each motor? Im just not sure which pins to wire them too on the control box you see
    Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
    not always the same I'm afraid. I've had to switch single pairs of wires around before.
    Do you have a model number on the stepper so you could google search a manual?
  3. Manual? christ chance would be a fine think lol.
    Motors have this labelled on them:
    Anchuan
    57HD0401-15SB
    1.8 2OA N1606
    Will it do any damage to the circuitry in the control box or the stepper motor if I just try trial and error ? or would it be impossible to work out?
    My build blog:
    Chinese 3020t Build
    Do you own a multimeter?
    You just need to match your pairs really then polarity can be trial and error... see this guide here if you need help with how to do it:
    http://42bots.com/tutorials/stepper-...wiring-how-to/
  5. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  6. Mate that is very very helpful. Im just trying to sort some 4 core cable out from somewhere then I will get investigating.
    Cheers pal
    My build blog:
    Chinese 3020t Build
  7. #6
    No problem.
    Just actually found this which is perhaps a slightly clearer explanation (especially regarding direction) and gives some other techniques if you lack a multimeter... though I'm not sure I would trust the complete trial and error one with expensive drivers/motors, but that's just my paranoia probably!
    http://reprap.org/wiki/Stepper_wiring
  8. #7
    you need to use a multimeter ( or a simple battery & bulb continuity tester )to confirm which two wires goes to each motor winding
    if you find you have 3 ohms or so between the red & yellow wires connect them to A+ and A- on your driver
    you should then find you that you have 3 ohms or so between the
    blue & green wires which you should connect them to B+ and B- on the stepper driver
    not all stepper drivers have the required fault protection to survive any connection between the A & B terminals
    if you find the motor runs the wrong way you can either change it in the controllers software - eg mach 3 changing the direction pin from active high to active low
    or
    reversing the wires on one winding
    eg
    changing from
    red to A+ and yellow to A-
    to
    red to A- and yellow to A+
    John
  9. The Following User Says Thank You to john swift For This Useful Post:
  10. #8
    Take any 2 wires from the 4 and cross them together and try and turn the motor shaft. When you feel resistance you have a matched pair. (The stepper's are working as a generator)
    Then wire 2 pairs next to each other in the 4 pin connector.
    Try it if the motor's run the wrong way either swap the wires around or change the setting in the firmware to invert axis.
  11. The Following User Says Thank You to Desertboy For This Useful Post:
  12. thanks very much, very helpful, also is this cable ok to use for my wiring:
    http://uk.rs-online.com/web/p/multic...cable/6604037/
    My build blog:
    Chinese 3020t Build
  13. #10
    Lives in Marple Stockport, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by ravihotwok View Post
    I would go for a screened cable like 4 core CY. https://quickbit.co.uk/Cable/CY-Cabl...-0-75mm-4-core
  14. The Following User Says Thank You to Clive S For This Useful Post:
  1. Replies: 1
  2. Stepper motor tunning wiring
    By handyoodman03 in forum Stepper & Servo Motors
    Last Post: 11-01-2013, 05:49 PM
  3. CY or SY cable for stepper motor wiring?
    By Jonathan in forum General Electronics
    Last Post: 26-09-2010, 06:25 PM
  4. Stepper motor wiring
    By Buba b in forum Stepper & Servo Motors
    Last Post: 28-03-2010, 06:16 PM
  5. Stepper Motor Wiring (Screened?)
    By pequod in forum Stepper & Servo Motors
    Last Post: 03-08-2009, 10:15 AM
