Thread: Stepper Motor Wiring
Take any 2 wires from the 4 and cross them together and try and turn the motor shaft. When you feel resistance you have a matched pair. (The stepper's are working as a generator)
Then wire 2 pairs next to each other in the 4 pin connector.
Try it if the motor's run the wrong way either swap the wires around or change the setting in the firmware to invert axis.Last edited by Desertboy; 15-07-2017 at 10:33 AM.
The Following User Says Thank You to Desertboy For This Useful Post:
17-07-2017 #2
thanks very much, very helpful, also is this cable ok to use for my wiring:
http://uk.rs-online.com/web/p/multic...cable/6604037/
17-07-2017 #3
I would go for a screened cable like 4 core CY. https://quickbit.co.uk/Cable/CY-Cabl...-0-75mm-4-core
17-07-2017 #4
hello Clive mate,
yes now that I have been doing a bit of readying screened seems to be the preferred cable to reduce interference or something. Im trying to also find a cable with the same colours as my existing cable (red, blue, green and yellow)
17-07-2017 #5
17-07-2017 #6
Don't worry about the colours of the wire, as long as you connect the wires correctly colour is irrelevant to the home builder.
If this was a commerical product you were reselling you might have issues with colour.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
26-07-2017 #7
Cheers mate :-)
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Stepper motor tunning wiring
By handyoodman03 in forum Stepper & Servo MotorsReplies: 47Last Post: 11-01-2013, 05:49 PM -
CY or SY cable for stepper motor wiring?
By Jonathan in forum General ElectronicsReplies: 6Last Post: 26-09-2010, 06:25 PM -
Stepper motor wiring
By Buba b in forum Stepper & Servo MotorsReplies: 5Last Post: 28-03-2010, 06:16 PM -
Stepper Motor Wiring (Screened?)
By pequod in forum Stepper & Servo MotorsReplies: 19Last Post: 03-08-2009, 10:15 AM
