18-07-2017 #2
Thanks for the advice, tool manufacturer said the slow speed is down to heat, if there is too much heat build up then instead of cutting the flute clogs, putting extra pressure on the axis motors as the fluted are no longer cutting, then stall detect turns motors off.. So lower rpm , 7-10,000 rpm can keep tool cooler, and avoid resin melting if that's the problem.basically he said its entirety dependent on the exact property of the carbon resin.
Carbon Fibre Composite Sheet Test Cut
By magicniner in forum General DiscussionReplies: 5Last Post: 21-08-2016, 08:56 PM -
Water bath for cutting Carbon fiber sheet
By Kendrick57 in forum Machine Frames & BedsReplies: 1Last Post: 25-02-2015, 09:14 PM -
NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
By Tomcat in forum New Member IntroductionsReplies: 0Last Post: 03-03-2013, 01:43 PM -
Which of these bits for carbon fiber and fiber glass?
By craigrobbo in forum Tool & Tooling TechnologyReplies: 5Last Post: 28-02-2013, 01:03 AM -
Carbon fiber keyrings...
By Jonathan in forum General DiscussionReplies: 4Last Post: 08-03-2011, 02:39 PM
