Thread: New start
    Just re-read the whole thread and I may have missed it again, but did not see how do you connect the two extrusions to each other? What is their size BTW?
    Quote Originally Posted by Zinci View Post
    I used 40x80 extrusion, most recommend 45x90 but this size was more availible for me.
    If doing it again I would order 45x90 :)
    Connected the profiles with t nuts in one extrusion. Then drilled through the other to be able to screw it together. Thought this would make a nice 90degree angle all by itself but I was misstaken! Have since loosened the bolts and retightened them while checking with a engineers square.. now I have a much better alignment!
    Ofcourse the endplates help. Had them milled by a happy forummember with accurate hole placement for easy alignment.
    Hope to get some free time soon to continue with the build ;) Christmas period has been hectic!!
  3. The Following User Says Thank You to Nr1madman For This Useful Post:
    Thanks for taking the time to reply, and thanks for a great build.
    Do you have space behind the ball screw, to put a L-bracket instead? Like in this Photoshoped photo?
  5. #4
    That's not necessary with the construction that is shown as the two profiles will be bolted together as have been mentioned by drilling the top profile in three places and fixing with tee nuts to the bottom profile
  6. #5
    Whaaat! Three places is enough? :D
    Think I did eight..
  7. #6
    You know what, that might work but I think you would need a plate to join the fronts as well.. otherwise it might fold backwards?
  1. NEW MEMBER: We all need to start somewhere!
    By Realtime in forum New Member Introductions
    Last Post: 16-05-2017, 08:43 PM
  2. NEW MEMBER: A new start for me.......
    By Nthkentman in forum New Member Introductions
    Last Post: 23-08-2014, 10:50 AM
  3. Where to start?
    By Inquisitor in forum Gantry/Router Machines & Building
    Last Post: 27-11-2012, 02:35 PM
  4. where to start
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 22-09-2012, 11:29 AM
  5. is this 2.5d where do i start? help please if you can
    By h4ppy-chris in forum General Discussion
    Last Post: 29-03-2011, 12:21 PM
