Thread: New start
Another one Lives. Well done that man.
21-03-2018 #2
It's always nice to see a machine move for the first time
21-03-2018 #3
Nicely done !
21-03-2018 #4
21-03-2018 #5
Woohoo!!! Nice!!!
21-03-2018 #6http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
21-03-2018 #7
Thanks for the support! Couldn't have done it without you!!
Tomorrow I'm going to try to verify steps per mm , square the gantry with sensors :)
Dont think I will have time for all limits, all homes, cleaning up the cable jungle in the control cab.
Those things come later, I think spindle is next and then cutting something :D
21-03-2018 #8
Well done man!!! Excellent work!!!
22-03-2018 #9
Okey, Im now in trouble again after mayor brainfreeze :)
Have routed my homeswitches.
I connected them in parallell.
Brown wire = 24v
Blue wire = gnd
Black wire = signal to bob
If I use this config I get 24v when measuring between black and blue.
If one switch gets close to steel they all light up and the voltage goes to 0 between black and blue.
If I use this paralell connection the bob gets supplied with 24v on the output pin?
Should I instead connect it in series ?
Can't get my mind around this :)
22-03-2018 #10
Home switches, or limit switches? If all are going to a single input, then limit... What input (although you said output) are you connected to on BOB? E-Stop? Regardless, your BOB is probably looking for 5V, yes? If so, you need to make a voltage divider to take that 24V to ~5V - maybe an 18K/4.7K resistor divider.
OTOH, I don't know squat about your BOB, controller, etc., so maybe I should just zip it...Last edited by wallyblackburn; 22-03-2018 at 01:53 PM.
NEW MEMBER: We all need to start somewhere!
By Realtime in forum New Member IntroductionsReplies: 0Last Post: 16-05-2017, 08:43 PM -
NEW MEMBER: A new start for me.......
By Nthkentman in forum New Member IntroductionsReplies: 4Last Post: 23-08-2014, 10:50 AM -
Where to start?
By Inquisitor in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-11-2012, 02:35 PM -
where to start
By martin54 in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 22-09-2012, 11:29 AM -
is this 2.5d where do i start? help please if you can
By h4ppy-chris in forum General DiscussionReplies: 4Last Post: 29-03-2011, 12:21 PM
