Thread: New start
    UC have a USB or ethernet solution, Jazz was comparing using a PC with PP for step generation. UC cards are step generators. It gets confusing because like me nr1madman is using a cheap PP BOB to connect to the steppers, switches etc.
    but the connection to the PP BOB is running a lot faster than if it was a PC PP. A few people have warned that using that cheap board will limit upper performance but I was told you will be able to run at least 50khz per axis with that cheap board connected to a step generator if you need more you need a better breakout board. For my Mesa card it's £100 for the better BOB so I'm happy to use my existing BOB for now and 50khz is actually a lot depending how you set microstepping.
    And just to clarify (I have no clue)
    If running 1600 microsteps and 10mm pitch screw with the standard 200steps/rev motors.. how fast will 50khz get me? :D
    LOL I'm going to run 16 microsteps ;) so 100 times less
    Jazz is the man to ask but I think
    50000*60 == 3000000 pulses per minute /1600 = 1875 revolutions per minute I think, times that by pitch for distance.
    Hmm... I might be over thinking this!
    Maybe I was thinking about 1600 pulses so 8 microsteps per step.. have to rethink :D
    That's ok because I should have divided the last one by 200 ha ha ha forgot the steps.
    Alright.. now Im really really tired of wires :D
    Got the pc working and installed uccnc sucessfully!! Makes me want to scream in joy!
    As Ive said before Im following a schematic I found on the forum.
    But in this schematic the limitswitches power a relay and this enables a signal to the bob.
    Shouldnt the limitswitches be connected with the estop circuit and stop the main relay from latching?
    That way the power would be cut if a limit is breached?
    Otherwise the axis that hits a limit might continue if there is software malfunction?
    Do you have soft limits as well? It's all debatable but hitting the limits say while jogging should not (in my opinion) be an E-Stop as it is not an emergency
    Robert in the name of Odin, can you share the schematic, or point the thread? :-)
    This is why I would always recommend running soft-limits. IMHO the type of machine decides the limit system used - A stepper drive is safe if it runs away and hits a stop, the steppers will stall so I would forget limits altogether and fit a home switch plus soft limits, nothing more.
    On a servo drive, mechanical breakage is very easy so i would fit hard limit switches wired to the servo power/estop circuit contactor, forget the software, just kill the power. Then fit a home switch and use soft limits to ensure you cannot jog into a limit, ever.
  1. NEW MEMBER: We all need to start somewhere!
    By Realtime in forum New Member Introductions
    Last Post: 16-05-2017, 08:43 PM
  2. NEW MEMBER: A new start for me.......
    By Nthkentman in forum New Member Introductions
    Last Post: 23-08-2014, 10:50 AM
  3. Where to start?
    By Inquisitor in forum Gantry/Router Machines & Building
    Last Post: 27-11-2012, 02:35 PM
  4. where to start
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 22-09-2012, 11:29 AM
  5. is this 2.5d where do i start? help please if you can
    By h4ppy-chris in forum General Discussion
    Last Post: 29-03-2011, 12:21 PM
