Thread: New start
30-03-2018 #2
Good morning!
Lovely day today, gonna tidy up some wires and see if I get better results :D
Any feeds and speeds tip for surfacing plywood with a 12mm 4 flute endmill hss.
Not really a suitable tool but the biggest I got right now :)
Have figured out that 1 or 2 flute would be better!
30-03-2018 #3
4500rpm, 4000mm/min 2mm DOC, full width.
Definitely not the ideal tool :)
30-03-2018 #4
Do not hurry now,try to get a bigger one,a bit with a cutting surface about 20 or more mm will save you much working time from the machine an d a better result.
30-03-2018 #5
30-03-2018 #6
I bought a 12.7mm 2 flute trend straight router cutter for wood and found it has a far better finish than the 2 flute carbide endmills I bought from China. The 2 flute carbide endmills leave an excellent finish with aluminium.
I used 18mm MDF which in the UK is the same price as ply but machines better and is flatter but you loose the ability to mist with oil for aluminium cutting.Last edited by Desertboy; 30-03-2018 at 10:13 AM.
30-03-2018 #7
30-03-2018 #8
30-03-2018 #9
Bits for woods are better for this job,I found bits for metal at a very good price on flee market some months agoade in Germany and make some tests on several scrap woods, the results are not as good as the one I have with wood bit.
If you can find a bit at a good price with bearing at the end,take it remove the bearing and trim the insert point flat with a Dremel or a similar tool....
30-03-2018 #10
NEW MEMBER: We all need to start somewhere!
By Realtime in forum New Member IntroductionsReplies: 0Last Post: 16-05-2017, 08:43 PM -
NEW MEMBER: A new start for me.......
By Nthkentman in forum New Member IntroductionsReplies: 4Last Post: 23-08-2014, 10:50 AM -
Where to start?
By Inquisitor in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-11-2012, 02:35 PM -
where to start
By martin54 in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 22-09-2012, 11:29 AM -
is this 2.5d where do i start? help please if you can
By h4ppy-chris in forum General DiscussionReplies: 4Last Post: 29-03-2011, 12:21 PM
