Got my z axis running like a kitten today :D
So movement seems good!
Connected vfd and spindle, starts and runs in the right direction :D
Have connected the relay on the bob and 1-10v on the bob to the vfd.
Now I have to set up the vfd.
Don't look forward to this!!
Have found several "guides" and lots of them contradict each other. Confusion is complete!
Think I will follow this guide...
The VFD parameters
First, reset the VFD to factory settings. You don't know where that thing's been. On the front panel, hit PROG (or PRGM), and then the up and down buttons until you reach*PD013. Hit SET. Change the value to 8 using the up and down buttons. Hit SET again. Now your VFD is reset.
For the next parameters, I've renamed them to make some kind of sense. For setting multi-digit values, use up and down to increase and decrease the value, and the >> key to move one digit to the right.
PD001:*Command source. Set to 0. 0 means you're controlling the spindle via the front panel controls. 1 means you're using controls that you've wired up to the screw terminals. 2 means you're going to control it using RS-485.
PD002:*Speed control source. Set to 1. 0 means you're controlling the speed through the up and down front panel buttons. 1 means you're going to control the speed with either the knob on the front or an external potentiometer. 2 means RS-485.
When PD002 is set to 1, there is also a jumper next to the screw terminals that you have to set. If the jumper is on the right pair, the control is the front panel knob. If the jumper is on the left pair, the control is via an external potentiometer connected to the screw terminals. Make sure the jumper is on the*right-side pair.
By the way, I found setting 0 pretty weird. You only get to see the speed as a frequency, not as RPM.
PD003:*Default frequency. If PD002 was set to 0, this is the frequency the motor will start running at. The frequency is directly related to the speed. Since we set PD002 to 1, we can leave this alone. But you can set it to something like 200 Hz to start at mid-range.
PD004:*Rated frequency: Apparently this is for motors with a fixed frequency. Since the spindle is variable frequency, this setting can be ignored.
PD005*through*PD010*set three points on a voltage/frequency curve. As the motor ramps up to your desired speed, it follows this curve. The manual usefully shows three types of curve: constant torque, low torque, and high torque. I've set mine to the values for the constant torque graph (why not).
I think that if you get a VFD with a spindle, the particular model of VFD comes with different factory settings for these depending on the spindle. Which is nice.
PD005:*High-end frequency: 400 Hz
PD006:*Middle frequency: 2.5 Hz
PD007:*Low-end frequency: 0.5 Hz
PD008:*High-end voltage: 220 V
PD009:*Middle voltage: 15 V
PD010:*Low-end voltage: 8 V
PD011:*Minimum allowed frequency. Set to 120 Hz. Air-cooled spindles are not meant to stay at low speeds, otherwise they overheat. I understand that water-cooled spindles can go as slow as you want.
Leave the next parameters alone, and skip to...
PD070:*Speed control input: Set to 1. This means that the speed will be controlled by an input voltage between 0 and 5V. This is what the front panel knob delivers. 0 means 0-10V. 2 means the control is by an input current between 0 and 20mA. 3 means 4-20mA. 4 is a combination of voltage and current.
PD071:*Speed control responsiveness: Leave at the factory setting of 20.
PD072:*High-end frequency: Set to 400. This sets the frequency represented by the top end of the speed control.
PD073:*Low-end frequency: Set to 120. This sets the frequency represented by the bottom end of the speed control.
Now skip straight to...
PD141:*Rated motor voltage: Set to 220V.
PD142:*Rated motor current: Set to 10A.
PD143:*Number of motor poles: Set to 4. This is the number of magnetic poles in the motor. It should be either 2 or 4, and is 4 for the 2.2kW spindle.
PD144:*RPM at 50Hz: Set to 3000. Since the max RPM is 24000 at 400Hz, this means that the RPM at 50Hz will be 3000.
That's it!
Looking good those who know?
