Thread: New start
02-04-2018 #2
Thanks for the help guys!
I'm greatly relieved that my weak camskills are the culprit :)
Guess do it again, do it right is in order!
02-04-2018 #3
Strange code that what did you create it in.?
02-04-2018 #4
02-04-2018 #5
02-04-2018 #6
03-04-2018 #7
New day and new questions :D
I fused my 24v psu with a 2A fuse.
But now that I think about it.. must be wrong?
The psu is 24v / 2A but thats on the secondary side.
Input is 50w so fuse should be around 0.25A.. correct?
My toroid is 500VA so without inrushcurrent 2.2A fuse should be enough? I fused 2.3A but that kept blowing every 5-7times I powered up. Exchanged for a 3A and now it seems okey but is it still protected?
I'm wanting to exchange to MCB type of fuses. Now I have 5x20 glassfuses. Not really easy to find MCB with these kind of ratings :)
03-04-2018 #8
Re. 24V PSU - you're broadly correct - though personally I'd give it a little more headroom (rough rule-of-thumb is 125%) - probably 300mA, and with a power-supply then use an anti-surge or time-delay fuse.
For the toroidal transformer an anti-surge is a must, though I'd* even go as far as installing a NTC thermistor in series with the primary coil to limit the inrush current.
* wrong tense : I'm building up a PSU now for my next machine - NTC thermistors on order, SSRs on order - in the mistaken belief that zero-crossing would be a good thing - but a little googling reveals the role of the NTCs.
03-04-2018 #9
03-04-2018 #10
I have NTC on my transformer was a bitch to get the right one. I have no issues running it without NTC (Doesn't trip anything) but the real advantage for me is I can use a MCB type a if you use NTC for extra protection, remember I blew a transformer up already lol.
We're 99% certain we plugged the bridge rectifier in back to front during testing but you're not using one are you?
I have a 1kva transformer 45v output (70v when rectified)Last edited by Desertboy; 03-04-2018 at 08:40 AM.
NEW MEMBER: We all need to start somewhere!
By Realtime in forum New Member IntroductionsReplies: 0Last Post: 16-05-2017, 08:43 PM -
NEW MEMBER: A new start for me.......
By Nthkentman in forum New Member IntroductionsReplies: 4Last Post: 23-08-2014, 10:50 AM -
Where to start?
By Inquisitor in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-11-2012, 02:35 PM -
where to start
By martin54 in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 22-09-2012, 11:29 AM -
is this 2.5d where do i start? help please if you can
By h4ppy-chris in forum General DiscussionReplies: 4Last Post: 29-03-2011, 12:21 PM
