Thread: New start
30-03-2018 #291
4500rpm, 4000mm/min 2mm DOC, full width.
Definitely not the ideal tool :)
30-03-2018 #292
Do not hurry now,try to get a bigger one,a bit with a cutting surface about 20 or more mm will save you much working time from the machine an d a better result.
30-03-2018 #293
30-03-2018 #294
30-03-2018 #295
I bought a 12.7mm 2 flute trend straight router cutter for wood and found it has a far better finish than the 2 flute carbide endmills I bought from China. The 2 flute carbide endmills leave an excellent finish with aluminium.
I used 18mm MDF which in the UK is the same price as ply but machines better and is flatter but you loose the ability to mist with oil for aluminium cutting.Last edited by Desertboy; 30-03-2018 at 10:13 AM.
30-03-2018 #296
I think mdf is cheaper here, depending on the quality of the ply. Marine ply and birchply is insanely expensive :)
The ply Im using is scraps from my shed, to get me started!
When I feel somewhat secure, safe and possibly tipsy I will bring out the oak :D
Want to find a local supplier of varieties of endmills. The only thing the stores here sell are for handrouters. Oftentimes with bearings :(
A nice singleflute for acrylic would be nice.
Aswell as some downcuts for soft wood!
30-03-2018 #297
30-03-2018 #298
Bits for woods are better for this job,I found bits for metal at a very good price on flee market some months agoade in Germany and make some tests on several scrap woods, the results are not as good as the one I have with wood bit.
If you can find a bit at a good price with bearing at the end,take it remove the bearing and trim the insert point flat with a Dremel or a similar tool....
30-03-2018 #299
30-03-2018 #300
A 2mm single flute carbide tool in alu will be needing 30k+ rpm - these spindles are slow compared to some, even 5-6mm single flute will need 24k rpm.
Single flute work well as they are pretty strong and have a lot of chip-space in the flute.
When you get down to sub 1mm tools you need mega-rpm.
Don't forget these motors are sold as engraving spindles - the tools are sharp pointed and can take any rpm you have.Last edited by Davek0974; 30-03-2018 at 09:37 PM.
NEW MEMBER: We all need to start somewhere!
By Realtime in forum New Member IntroductionsReplies: 0Last Post: 16-05-2017, 08:43 PM -
NEW MEMBER: A new start for me.......
By Nthkentman in forum New Member IntroductionsReplies: 4Last Post: 23-08-2014, 10:50 AM -
Where to start?
By Inquisitor in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-11-2012, 02:35 PM -
where to start
By martin54 in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 22-09-2012, 11:29 AM -
is this 2.5d where do i start? help please if you can
By h4ppy-chris in forum General DiscussionReplies: 4Last Post: 29-03-2011, 12:21 PM
