Thread: New start
15-05-2018 #371
15-05-2018 #372
15-05-2018 #373
This might be it.. not power setting but background programs.
I have checked power settings and they are set to "always on"
I'm using my old home computer so there are all sorts of programs installed. Should test reinstall but I have no valid windows cds left. Stuff like that gets destroyed some were between child 2 and 4 ;)
Its still strange that it starts to happen after about 2h and not when running pockets and contours just 3d....
15-05-2018 #374
It might not show as a full loss of connection but does cause's an interrupt just long enough to trick controller. These are the Silly tricks USB gets upto and why I won't use it.!!
Also do you know for sure that UCCNC displays connection lost message and doesn't just throw a Generic E-stop message if doesn't fully lose connection.?
15-05-2018 #375
Well during large noise problems (tried unshielded vfd wire) uccnc looses connection with uc300 and can't be reset without disconnecting usb and reconnect.
That is way worse then e stop.
Now when it e stops I can just reset, run spindle and then start cycle again.
But for every time I do so it will run a shorter time before it e stops again :(
15-05-2018 #376
USB will generally just fail/lock up. If you do get problems with that, get a USB isolator.
Search ebay for "USB Isolator", and get one that uses an ADUM chip (I think most of them do).
However, it sounds like you have a noise problem.
Simple fix is to add a small capacitor to the E-stop input to the controller to act as a basic noise filter, but depending on your e-stop circuit, it may be better to add a resistor to increase the load on the circuit so noise isn't as big a problem.
The only concern with those fixes is, the noise may be affecting other things, but not as noticeably I.e. lost/gained steps.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
15-05-2018 #377
15-05-2018 #378
15-05-2018 #379
15-05-2018 #380
Is the E-stop a dedicated pin, or configurable to any pin?
NEW MEMBER: We all need to start somewhere!
By Realtime in forum New Member IntroductionsReplies: 0Last Post: 16-05-2017, 08:43 PM -
NEW MEMBER: A new start for me.......
By Nthkentman in forum New Member IntroductionsReplies: 4Last Post: 23-08-2014, 10:50 AM -
Where to start?
By Inquisitor in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 27-11-2012, 02:35 PM -
where to start
By martin54 in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 22-09-2012, 11:29 AM -
is this 2.5d where do i start? help please if you can
By h4ppy-chris in forum General DiscussionReplies: 4Last Post: 29-03-2011, 12:21 PM
